Lnf turbo manifold on l61
Does anyone know if the lnf turbo manifold is useable on a l61? Any modification needed?
serious modification is needed and it doesn't really work all that well. The SAAB LK9 intake manifold will work better with less modification.
Also the stock intake manifold seems to work fine for most guys as long as you don't plan on running extremely high boost pressures. |
Can the k04 be used with this saab manifold?
Sorry I was for some reason thinking the intake manifold. The exhaust manifold should work without issue, other than needing the LNF's crossover coolant pipe.
Yes it fits, but i would recommend the sce copper exhaust gasket. And you need the lnf coolant pipe/tstat housing.
does anyone know what flange the LNF turbo uses?
A proprietary gm flange
(Post 7643170)
