Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.2L L61 Performance Tech (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/)
-   -   lowering compression question! (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/lowering-compression-question-135229/)
Ec0t3cHp0w3r Sep 25, 2008 06:32 PM
Would my compression drop any if i add an mls head gasket? if so how much? need 2 know cause i am goin turbo soon
08turbo'dSS Sep 25, 2008 06:33 PM
no it shouldnt
Ec0t3cHp0w3r Sep 25, 2008 06:34 PM
dam. do u know how i can?
08turbo'dSS Sep 25, 2008 06:38 PM
how u can drop the compression? Swap out the pistons.
http://www.turbotechracing.com/produ...idproduct=2730
that will lower your compression. You dont have to lower your compression to go turbo, just don't run as much boost. The stock pistons can't handle alot of boost on high compression, but if your tune is good, you can make just as much power on low boost with high compression, as you would on lower compression and higher boost
Ec0t3cHp0w3r Sep 25, 2008 06:48 PM
soo basically ill b fine with a good tune but with low boost and high compression... but if i wanna up the boost i need 2 lower the compression by adding the pistons? srry i am new 2 turbo:lol: i just bought head studs so the motor can take alil beating and i may buy an mls gasket just 2 b 100% safe. wat is the stock thickness of the head gasket? and would 8lbs b good with a good tune?
HunterKiller89 Sep 25, 2008 06:56 PM
Originally Posted by Ec0t3cHp0w3r (Post 2926667)
soo basically ill b fine with a good tune but with low boost and high compression... but if i wanna up the boost i need 2 lower the compression by adding the pistons? srry i am new 2 turbo:lol: i just bought head studs so the motor can take alil beating and i may buy an mls just 2 b 100% safe. wat is the stock width of the head gasket? and would 8lbs b good with a good tune?
I would research the breaking points of the engine a bit before you start buying parts for them. A head gasket and head studs are not needed if those are the only thing your putting into the car. people buy those so they can reassemble their cars after building the bottom end. The parts your going to want to worry about are pistons and rods, but on 8 psi, you wont need to upgrade anything. the L61 can hold 250hp on stock everything pretty well. Once rods and pistons are upgraded, your pretty set for 500hp as far as break points, though at that point your going to want to do things like port the head, etc.
Ec0t3cHp0w3r Sep 25, 2008 07:07 PM
soo shit the head studs i just bought i dont need..... lol
o and is that shift+ worth buying?
YSUsteven Sep 25, 2008 07:19 PM
The only wahy that a head gasket will drop the compression is if it is thicker than the origional gasket. It would have to be much thicker to affect the compression to any extent.
HunterKiller89 Sep 25, 2008 11:06 PM
they make them. Hahn has a good example. They use a thick head gasket to reduce compression in their solstice/sky turbo kit from 10.4:1 to 9.X:1. this is for the 2.4l ecotecs of course.
umrdyldo Sep 25, 2008 11:40 PM
Yes a different head gasket will change compression, but lower compression pistons is what you want.
Ec0t3cHp0w3r Sep 26, 2008 01:19 PM
i thought it would... how thick is the stock gasket???
IonNinja Sep 26, 2008 06:17 PM
stock headgasket I believe is .040"
thats what I run with with my Cometic head gasket
as a general rule, thinner headgasket will slightly raise compression and thicker of course will lower it. whether or not it will be a significant change or not, I can't comment.
also head studs are not a bad idea, I doubt you'll be running enough boost on stock bottom end to lift the head though
YSUsteven Sep 26, 2008 07:49 PM
I have never even heard of such a thing... Learned something new today. :cssNET:
