The Phoenix Rises Once More
So, those of you that know me, or at least know of me, know that I am not normal. Hell I probably have something super wrong with my head, after all I've built what I think is the only Cobalt Time Attack car that wasn't handled by John Powell. We have built a team, and have some awesome sponsors that help us out, to build and prove that the Cobalt can and will hold its own vs the Honda Time Attack Fleet in the USA.
Lets go into a little back story on this car. Purchased Sept 2005. So fresh, so clean. Engine #1 (Stock L61) Let go back in 2009 with a spun crank bearing at 120,000 miles. https://cimg7.ibsrv.net/gimg/www.cob...b02df197aa.jpg Engine #2 (Junkyard L61) Lasted 14,000 miles before it got more rod knock than.... well, lets just say running 90w in the crank case wouldn't quiet it down..... https://cimg4.ibsrv.net/gimg/www.cob...c967e2622b.jpg Engine #3..... A very nice fully built L61 I picked up off a member on here when I was still in Pittsburgh. It was built for a turbo, and for 2 years I ran it NA (and was sad) Then put a blower on it. Trifecta was super awesome and Steve did a lot of work with us when I moved to SoCal to get us better for Time Attack. But with around 60k on the motor, we did this. and blew a hole thru cylinder #1. I think we had hurt the motor at Super Lap in 2015, but then we went SUPER LEAN at GTA Rd 1 this year and yeah... Melt. https://cimg3.ibsrv.net/gimg/www.cob...c9ead6b6fb.jpg So now...... https://cimg1.ibsrv.net/gimg/www.cob...becb4e7109.jpg (DEI makes some AWESOME heat shield) The Phoenix will be rising again soon, and this build will be absolutely nuts. Doing a few of those "You shouldn't try this, it will be too hard / too much work" and some ridiculous upgrades are coming..... I will be using this thread to tease and post things as we are now getting closer to the motor coming back together...... |
Sub'd for updates. Got any more info on the DEI heatshield stuff?
le5 time :spam:
Originally Posted by ECaulk
(Post 7618263)
(Post 7618265)
le5 time :spam:
lsj head swap?
(Post 7618267)
lsj head swap?
Subd for updates
So, while we wait for the Custom Arias pistons to come in, heres another shot of the block getting ready:
Out with the old, stock sleeves.... https://cimg9.ibsrv.net/gimg/www.cob...ad41bc7df8.jpg Stock L61 Sleeves And in with some tasty Powerbore Ductile Iron Sleeves https://cimg2.ibsrv.net/gimg/www.cob...6ab178a820.jpg New Powerbore Sleeves |
What all does it take to swap out sleeves?
holy shit. I've never seen a set of JE pistons with a hole like that in them. you must have gotten that bad boy HOT lol
Going 2618 Arias or 4032?
I still run that sway bar I bought off you like 6 years ago :lol:
(Post 7618899)
Originally Posted by jdbaugh1
(Post 7618888)
(Post 7618888)
Originally Posted by Foximus
(Post 7618936)
Neither. These are 1 off custom's they are machining for us.
So..... Trevor sent these shots the other day as well.
https://cimg9.ibsrv.net/gimg/www.cob...82bd97055e.jpg https://cimg8.ibsrv.net/gimg/www.cob...1a68cc090e.jpg https://cimg7.ibsrv.net/gimg/www.cob...4a3ec022ef.jpg Should work nicely for a heat exchanger. |
That thing's a beast. With this size of heat exchanger I have always wondered at what capacity does it start not really making a significant difference based on the heat transfer limitations of the stock IM cores. I'd be curious to compare exiting water temps of different heat exchangers.
I love the car and what youve done with it. good luck
Best birthday present I coulda ever bought myself.
https://cimg0.ibsrv.net/gimg/www.cob...739a7eabc9.jpg |
Pistons come in Wednesday. Ill be picking up the car this weekend to start all the fab. lots to do so I cleared out all the projects I have to make room for this one car. other than some little BS things ill have everything to get the car running. Goal here is to gain 80-100 HP at the same boost level. car will definitely rip. After wat I learned from steves car with raised compression and the HEs I have been building this should easily make 320 ish HP with around 10 PSI of boost.
oh and once I get the car to my place there will be lost of pics so don't worry Foximous will have lots to post very soon.
Very cool man. Sub'd for more
Nice, make it happen.
What compression ratio are you guys aiming for?
