power steering problem
Old Jan 1, 2010 | 05:31 PM
ryanstammler's Avatar
Past few days after ive been driving my 2006 2.2 lt my power steering would stop working like around 10-90 seconds after i start driving. Looked through the manual no help at all, anyone know what the problem can be? When i restart my car it works fine then stops working again. Its getting really annoying!
Old Jan 1, 2010 | 07:33 PM
07cobaltguy's Avatar
if i remember ther brushes in the motor become worn or dirty, and stop the motor from working.
Old Jan 1, 2010 | 07:52 PM
is it an easy fix?
Old Jan 2, 2010 | 07:44 PM
tru2nrtt777's Avatar
No, you have to replace the whole steering rack, they dont sell the individual parts... I had to swap it when I got in an accident and it bent a tie rod... that was some bullshit.
Old Jan 2, 2010 | 10:02 PM
wow this car is problem after problem.... about to just get rid of it
Old Jan 2, 2010 | 10:03 PM
HyperMuffin's Avatar
no you dont
Go to a local chevy dealer.
Buy a power steering motor. It is a small black cylinder. Easy to instal. All you need to do is remove the panel from under the steering wheel and you will see the power steering motor. There are 2 or 3 bolts holding it in and a plug and then just unplug and unbolt it and put the new one in. Takes less than 20 minutes.
Old Jan 2, 2010 | 10:05 PM
G85 SS's Avatar
New steering column/motor is needed.
I have had my car in 3 times for this bullshit.
And that is low compared to some.
Old Jan 2, 2010 | 10:08 PM
Originally Posted by HyperMuffin
no you dont
Youre right, not sure what I was thinking. Back when I was in my accident you couldnt buy just the tie rod though, you can now(just checked with a buddy of mine who works at saturn)... more bullshit.
Old Jan 2, 2010 | 10:10 PM
Yeah, only bad thing is its a 200$ part.
OP just whatever you do, dont buy used. Its going to break just as fast and cost you more. Buy it new and install yourself and move on.
Old Jan 2, 2010 | 10:35 PM
CobaltSS89's Avatar
Is that really all you have to do is buy the new part the 2.0 has the same problem mine does the same as yours lol every single time I drive it goes out then when I turn it off then back on I have it back I read befor that it was 2 grand to fix cause they had to replace the whole steering column that's what I've heard befor not sure if its true or not but I have the same problem man
Old Jan 3, 2010 | 10:35 PM
So the motor is just dead? Ill just replace it and hopefully its fixed
Old Jan 4, 2010 | 07:29 AM
Yes. Its what I did on mine and has been perfect since then.
Old Jan 4, 2010 | 03:53 PM
LethalSS's Avatar
its just the motor. 10 minutes to replace, and its like $179 at the dealer.
Old Jan 5, 2010 | 01:53 AM
Thanks everyone
Old Jan 15, 2010 | 01:37 PM
ibanezrick's Avatar
About 2 years ago I lost power steering in my '06 Cobalt. Over the course of a month or two it got progressively worse, from only happening randomly to happening as soon as I drove more than 20 feet in a straight line. I replaced it with a used steering engine which worked great for about 2 months, then it went out again and I've just been dealing with it for over a year now. I called a Chevy dealer in town and they have a new engine in stock for $175. At first he tried to sell me the whole column for about $450, but after explaining that the steering engine should be available separately he drilled down to it. I'll update this post on Monday after I have it installed and working for the weekend. Then I'll update again in a few weeks to let you guys know if it goes out again at all.
Old Jan 15, 2010 | 03:38 PM
VictoryRedLT's Avatar
Cobalts are garbage, electrical nightmares same stuff happend to me and i dont think its worth putting the money into it to get it fixed (base LT model). Powersteering went, then my air bag sensor went, now everytime i come to a light and let the car idle the headlights flick and the interior lights (Cluster, HIVAC controls, radio lights) flicker and dim then the car starts to kinda mildly shake then once i start driving again its all gravy......idont know whats wrong (faulty ECU?), i think its the last chevy im gonna buy unless they get there **** together and make the cruze with quality parts and better electricals.
Old Jan 15, 2010 | 04:16 PM
Spanky's Monkey's Avatar
the new aveo rs looks better then the cruze
Old Jan 15, 2010 | 04:41 PM
818contrerasjus's Avatar
look bro i have the same problem with my 2005 ss/sc
i took the whole steering colum out and cleaned everything as good as i can...
i did it twice..and now my steering works...
Old Jan 20, 2010 | 08:46 PM
rickyw's Avatar
My power steering went out on me from freaking NC to florida..... Luckly I have had so many problems with the freaking car GM extended the warranty for me and they fixed it for free.... otherwise it would have been 800.......
Old Jan 21, 2010 | 11:22 AM
ibanezrick's Avatar
Steering Engine
I replaced the steering engine, not the whole steering column. I've been working perfectly for a week now, whereas it was going out after 20 feet of driving in a straight line before after getting progressively worse for a year. I agree with the prior post that it's probably just a matter of cleaning it really well.
The part costed $175. It took 5 minutes of work (plus 10 minutes to find the right socket in my messy garage.)
All you gotta do is pull off the panel below the steering wheel. Remove the 2 screws holding the steering engine in and screw the new one in. So easy a cavewoman can do it.
Old Jan 21, 2010 | 01:07 PM
RedBaseBolt's Avatar
For me the power steeling issue was the ground coroded and I needed to reground it.
After that I've never had the motor die on my yet.
Solaris99
28
Mar 15, 2017 01:22 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
Stuff
Oct 1, 2015 05:47 PM
