Running a clear filter before fuel rail?
Old Feb 28, 2019 | 11:59 PM
Bdawg977's Avatar
Would it be too stressful on the fuel pump if i ran a 2nd fuel filter that was clear just before the fuel rail so i can monitor whats pumping through the fuel system?
Old Mar 1, 2019 | 09:24 AM
steelmesh's Avatar
As long as the fuel filter is rated for your fuel pressure and fuel type, and large enough to handle the flow for you application it will work. When it gets dirty it will start reducing flow to the injection system, like any other fuel filter. If the micron rating is larger than the factory system then it's not going to do anything. Recommended to do 100 micro between the tank and pump, 10 micron at the fuel injectors (5 micron for DI).
https://www.deatschwerks.com/fuel-filter-faq
Old Mar 1, 2019 | 12:03 PM
Bdawg977's Avatar
Okay, thanks for the info
raynrishad
May 31, 2011 08:52 PM
jlong3382
Jun 11, 2010 08:07 PM
Rodimus_Prime
May 6, 2009 09:12 AM
NJHK
Tuning
Nov 4, 2007 07:30 PM
ericss
17
Aug 20, 2007 11:03 AM
