Secondary Air Injection on late production 2006 L61's
Old 06-22-2007, 12:57 AM
  #101
Jusday's Avatar
Originally Posted by OrngBalt
Check out the thread "restricted by SAI" We have spoken with Donna from Cobalt Addiction and if we can get a 2.2 with SAI in there, they would be willing to fabricate something which may become available. CEL is Check Engine Light, but the light itself is a MIL (Malfunction Indicator Lamp)
cool thanks. yeah if i was in NY i would gladly let them have my car to work on but i am on the other coast.
Old 06-22-2007, 01:55 AM
  #102
Mr.N00bLaR's Avatar
Wait, where in NY? lol
Old 06-22-2007, 03:59 PM
  #103
mrgoodwrench78's Avatar
finally
if you didnt read my last post then here it is this process was easier for me,so if u work at a dealer you can follow this word for word. if your vehicle has SAI then the rpo code is
NU3-emissions system california,connect the tech2 w/the candi module to your delta using the sps system request info from your vehicle,verify the vin matches and then connect to your dealerworld sps site. go through the procedure like normal,at the end you will be askedfor your tire size,transmission type,and emissions rpo.choose the rpo that is not NU3 then you will be able to eliminate the SAI pump and hardware. if u just get rid of the system you will need a plate to cover the diverter inlet on topof the manifold
Old 06-22-2007, 04:07 PM
  #104
OrngBalt's Avatar
Wait??? Is this legit? Are you telling me that the dealer can eliminate SAI? Will the car still pass emissions testing?
Old 06-22-2007, 05:09 PM
  #105
tonio5555's Avatar
Only one way to find out if its legit. It sounds somewhat reasonable, but is the dealer really able to change your emissions settings? If so this sounds promising.
Old 06-22-2007, 07:05 PM
  #106
I'm old school
Halfcent's Avatar
That looks like a real solution. And as long as you are not in California, that should be a completely legal solution.
Old 06-22-2007, 07:19 PM
  #107
Jusday's Avatar
but sucks for us in cali
Old 06-23-2007, 02:23 PM
  #108
OrngBalt's Avatar
NY is a bitch too... I am praying... anyone gonna try it out?
Old 06-25-2007, 06:08 PM
  #109
emissions
it should pass an emissions test the pump only runs @ startup, then it has zero functionality as far as whats coming out of your tail pipe
Old 06-25-2007, 06:34 PM
  #110
HunterKiller89's Avatar
it still flows air into the ehxaust fter startup...lowering ALL PPM statistics
Old 06-26-2007, 10:47 AM
  #111
not true
The Secondary Air Injection (AIR) System aids in the reduction of hydrocarbon exhaust emissions during a cold start-up. This occurs when the start-up engine coolant temperature (ECT) is between 5-50°C (41-122°F), and the intake air temperature (IAT) is between 5-60°C (41-140°F). The AIR pump operates 5-60 seconds after start-up.
The control module activates the AIR system by simultaneously supplying grounds to the AIR pump and the AIR valve relays. This action closes the relays' internal contacts. The AIR pump and the AIR control solenoid valve/pressure sensor assembly are in turn energized, the pump runs and the control/shut-off valve opens.
The AIR pump sends pressurized fresh air into the pipes/hoses through the open control/shut-off valve, and into the exhaust manifold. The extra air accelerates the catalyst operation, helping it to reach operating temperature faster. The AIR pump remains ON for a short period of time after the control/shut-off valve is commanded OFF. When the AIR pump is commanded OFF it will not run or be activated until the next vehicle start. When the AIR system is inactive, the closed AIR control/shut-off valve prevents air/exhaust flow in either direction.
this is a few paragraphs explaining how wrong that last guy is
Old 06-26-2007, 11:29 AM
  #112
I'm old school
Halfcent's Avatar
Thank you, but next time you don't have to close with a dick-head statement like that.
Old 06-26-2007, 11:48 AM
  #113
sorry delta guru, i just think that u should do alittle research b4 giving some info
Old 06-26-2007, 12:11 PM
  #114
D4u2s0t's Avatar
you can hear it turn on and off on a cold start. if you warm your car up, shut it off, and re-start, the sai does not come on. and the extra air makes my exhaust sound like complete ass when it starts up cold.
Old 06-26-2007, 02:51 PM
  #115
i stand corrected
Old 06-28-2007, 09:49 PM
  #116
so is it comfirmed that you can effectively delete the SAI on SAI equipped cars with a reflash using the non SAI flash?
Old 06-28-2007, 09:55 PM
  #117
OrngBalt's Avatar
I spoke with mrgoodwrench about this. He has done it for over 2000 miles on his manual. he needed to do some research on the auto and has determined it can be done as well. The only issue is getting a dealer to do it for you. Being that I am close to him, I might make the journey up there for this, but if you work at a dealership or have a really good one that you have connections in, they might do it for you
Old 06-28-2007, 11:33 PM
  #118
I'm old school
Halfcent's Avatar
I actually had a direct conversation with Tom at Crate Engine Depot and one of the techs that expects to come to the meet on July 7th. We plan on having a Tech 2 connected to GM Dealer World at the meet to see what exactly we can accomplish. I plan on reporting on it afterwards. Things we plan to check are:
SAI switchability
Tire size / speedo calibration adjustability
Gauge cluster swapping ability
speed limiter changes
There was one concern that the technician had concerning all of these issues. The VIN numbers. Since the VIN is stored in the ECM, GM Dealer World may not allow the ECM program to be changed because the changes asked for don't match the file information for that VIN. We'll see what happens.
Old 06-28-2007, 11:41 PM
  #119
OrngBalt's Avatar
Sounds good halfcent... def let us know what you find out. I really hope this all works out.
Old 06-29-2007, 01:37 AM
  #120
tonio5555's Avatar
SAI switchability
Wow, you're awesome man. Reps. I get the feeling that this is going to work out however as you said it may not be "legit."
Edit: "You must spread some reputation around before giving it to Halfcent again." LOL
Old 06-29-2007, 01:43 AM
  #121
Dave104's Avatar
Thank the lord i'm an 05 lol
Old 07-02-2007, 01:12 PM
  #122
07LSC's Avatar
wow, I just started reading about all this sai junk because it came up in a lot of threads and i had no idea wtf it was. I have an 07 and just ran out to check based from the pics at the start of the thread and I don't have it Sounds like a big pita for those who do. I live in florida though so I guess it doesn't matter too much because I could get rid of it with no problems since there are no emissions here.
Old 07-03-2007, 01:31 PM
  #123
Blown 4-banger's Avatar
This is odd, because my dad has an 06 Ion sedan, and it doesn't have this
Old 07-03-2007, 02:44 PM
  #124
Witt's Avatar
Correct me if I'm wrong, but I think someone said its a Cali emissions thing. My friend has an 06 2.2 and it doesn't have it either.
Old 07-03-2007, 03:01 PM
  #125
Mr.N00bLaR's Avatar
I have it and I am in NY.
Quick Reply: Secondary Air Injection on late production 2006 L61's
