Secondary Air Injection on late production 2006 L61's
Old 08-21-2007, 09:47 PM
  #201
shawn672's Avatar
Originally Posted by OrngBalt
you guys just both said the same thing. lol.
i think he was just restating so Halfcent knows he understands
Old 08-31-2007, 05:29 AM
  #202
BlacKRioT's Avatar
Sniff
This makes me sad...i cant find a dealer near arizona that will remove my SAI software!
Old 09-02-2007, 10:07 PM
  #203
redlined01's Avatar
if you put an intake on your car with sai will it hurt your performance since it is not gettin air back to the manifold
Old 09-03-2007, 05:47 PM
  #204
BlacKRioT's Avatar
it should still be getting the air it needs unless you removed that SAI
Old 09-03-2007, 06:10 PM
  #205
shawn672's Avatar
No. If you actually read the first post, you'd see SAI only runs on a cold startup for a few moments. It helps control emissions when your engine is cold and needs to idle to warm up. Basically this is useless, just some dumb act of state legislatures to help "control emissions" ya right lol
Old 09-07-2007, 12:40 AM
  #206
shawn672's Avatar
Can those of us with SAI use this?
CA Stainless Steel Header
http://www.cobalt-addiction.com/prod...s/headers.html
1st one on the top
Says without EGR...Did they mean SAI? No Cobalt's have EGR
Old 09-07-2007, 11:38 AM
  #207
I'm old school
Halfcent's Avatar
No SAI equipped car can use any current aftermarket header without completely removing the SAI system. And yes, EGR was a typo, that should have been SAI.
Old 09-07-2007, 11:59 AM
  #208
OrngBalt's Avatar
1st one on the top
sorry bud, thats a no go. But, Donna and Kenny at CA have said that if they got a 2.2 to work with, they would look into fabricating an aftermarket header for the 2.2's with SAI. The problem is they would need a 2.2 to do research on.
Old 09-07-2007, 12:29 PM
  #209
tonio5555's Avatar
True, I tried getting in touch with them, I offered them my car but I never got any response.
Old 09-07-2007, 12:33 PM
  #210
OrngBalt's Avatar
well, I just sent Donna a PM.. I had an epiphany. I ordered myself a LSJ manifold, so that means I will have a 2.2SAI laying around once installed. Maybe I could get with them and they would have the part for R&D. It would solve a big problem for many of the 2.2's and be good for them at the same time.
you ever get your car reflashed?
Old 09-07-2007, 01:22 PM
  #211
chucktheweasel's Avatar
Originally Posted by Halfcent
This completely depends upon your individual state laws. SAI is a result of California and New York emission laws (some other states too). Here in Illinois for instance, they run your car on a dyno with an O2 sensor stuck in your tail pipe and actually measure it directly. As long as it's within limits, your fine.
So since I live in NY, does this mean if I take my car to a dealership to have them remove the SAI they will not do it? Am I SOL when it comes to an aftermarket intake?
Old 09-07-2007, 01:29 PM
  #212
OrngBalt's Avatar
I dont think the average dealer is going to do a reflash for you. You are probably going to have to know someone. But keep in mind, it doesn't hurt to ask. Just call up and see if they will do it for you.
You can still get an intake. Many guys have done aftermarket intakes with a breather filter over the SAI opening. Or you can get the K&N intake, this has a connection for SAI.
The only thing that people want to change but are unable to is the Exhaust Header. At the current point in time, there are no headers or manifolds compatible.
Old 09-07-2007, 02:20 PM
  #213
shawn672's Avatar
How would this effect your exhaust flow if you have a highly restrictive header, but a less restrictive downpipe and catback
Still gonna gain 8-15hp from downpipe + catback?
Old 09-07-2007, 02:26 PM
  #214
tonio5555's Avatar
I don't know about 15hp, maybe 8-10hp. It's all really a guessing game though, only a dyno can be sure.
Old 09-07-2007, 02:32 PM
  #215
OrngBalt's Avatar
you will see gains by adding less restrictive DP and exhaust... think of the flow like water... its gonna slow down at the blockage but will then flow better once into the less restricted areas.
You will see a gain... just not the same kinda gain if you opened up the exhaust all together.
has anyone thought of just porting their SAI manifold?
Old 09-07-2007, 03:27 PM
  #216
A filter over the SAI opening won't throw a cel? What kind of filter would I use?
Old 09-07-2007, 03:37 PM
  #217
shawn672's Avatar
Something like this:
http://www.2kracing.com/product_info...oducts_id/1474
can be found at any local auto shop.
hmmm, not a bad idea orng. I already have the SS/SC's exhaust mani b/c it's an 07, suppose i could just port it out a bit.
anyone happen to notice a how to about this?
Old 09-07-2007, 03:55 PM
  #218
OrngBalt's Avatar
nope... i believe advanced or autozone has one with a heat shield. ask tonio555 he put on there and it is almost like it was designed for that hose.
see so you are already a step closer. there isnt a how to on porting the manifold but if you search the how-to blown4banger ported his SC and its the same principle. if you google it there is also a guy that does a series of how-to's on it. and that has some good hints as well. its for a turbo manifold, but again, same principles
Old 09-07-2007, 04:25 PM
  #219
Thanks a bunch guys! I will be putting my intake on Saturday the 22nd when my brother comes up and visits me. Let's hope it works out!
Old 09-09-2007, 10:38 PM
  #220
SSfamliywagon's Avatar
I work at a GM Chevy Dealer. I will be trying this soon to see if I can do it. I have complete access to all the tools and understand everything Halfcent is talking aboot. Should be easy. I"ll let you know.
Old 09-10-2007, 01:00 AM
  #221
tonio5555's Avatar
At autozone its called, "shielded breather filter" it can be found on the rice aisle. Should run about $15, fits PERFECTLY.
Old 09-11-2007, 12:46 AM
  #222
BlacKRioT's Avatar
this is upsetting....
Old 09-11-2007, 01:00 AM
  #223
shawn672's Avatar
do you mean
1. GM implementing SAI?
or
2. People on CSS shopping in the Autozone "Ricer" Isle?
LMFAO
Old 09-13-2007, 12:23 PM
  #224
Old Man's Avatar
Something along this line, crank case filter would work to use the other intake kits.
http://www.knfilters.com/search/prod...x?Prod=62-1170
Hell you dont even need a filter.
GM use to tuck the open rubber end under the battery's on alot of vehicles.
Only problem they had is with them sucking in water and then all you had to do was extend the hose to a dryer location.
As far as a header I cannot believe no one has made a adapter plate to hold that valve. Simple to do and easy to get a CARB#.
Old 09-18-2007, 10:18 PM
  #225
avenger09123's Avatar
Just went to the dealership....
Oh damn, I just ran to the dealership on the way home. They said it was "illegal" to remove the sai since it affects emissions. I personally think that is bull...... well I can't do anything about it now, I'm think about getting a program to edit and flash ECMs. But it wasn't a complete waste, I found out if the BCM and ECM don't match VIN's it won't start. But I was thinking, does anyone know how when a ECM program is pulled, it's stored? a binary file yes, but what format, I would like to get ahold of one and toy with it see if I can get EVERY portion to read, including VIN and where SAI is enabled or disabled. If I can do this, then I might be able to do any 2.2s reflashing. Can anyone help me in this endeavor?
Quick Reply: Secondary Air Injection on late production 2006 L61's
