yeah true, or I can find out the voltage for sure by sticking an Holmes meter between the sensor and the wire back to the PCM. You wanna roll by today or sunday we can give it a go?
Originally Posted by avenger09123
(Post 2193100)
i own 06 ls sedan with sai and one cat
Ok...
What size plug or flange would fit where the 02 sensor goes at the base of the header? i found a way to make it work for CA users.
I don't know, but the O2 sensor really has nothing to do with this system.
(Post 2192486)
Halfcent's right. No LSJ 2.0L or LNF 2.4L has , will, or ever will have the SAI system. SAI only comes on L61 2.2L motors, and even then, not on all of them, it seems they were made and spread out throughout delivery.
Originally Posted by Halfcent
(Post 2225295)
I think you are talking about the air injection hole, not the O2 bung, right? In that case, I still don't know exactly. But I do know that hole isn't threaded like an O2 bung. It just a plate with two bolts that hold it. So you could fab up a simple steel plate and drill the holes to match.
(Post 2225697)
Oh, well, you didn't mention that where trying to use a GMPP header. That's kind of important. I'm afraid I don't know. But I can tell you it still sounds like far too much work just for CARB requirements. Remember, this system only runs for like the first minute your car is on. If you are using an aftermarket header and trying to retain the system just to keep the CEL off, I would just leave the air injection line disconnected and venting to atmosphere rather then trying to plumb it into the O2 bung.
(Post 2227318)
Originally Posted by CobaltLs_14
(Post 2228332)
Oh So it only runs as soon as the engine starts up the cuts off? i dont know if i'm getting this right... but its not to much work its actually really easy if u know what your doing...
i'm not sure if i have SAI or not. but i think i do. the thing is that i installed a k&N CAI and ever since i did that my car idles when i turn it on. would SAI have anything to do with that?
Originally Posted by chrism0589
(Post 2249479)
what do you mean? |
Originally Posted by Sarbae
(Post 2251620)
your car idles when you turn it on? so does mine...
what do you mean? well when i turn it on. like in the mornings. the revs go down to like 300 then up to like 900 does that a few times then u hear like an air sound then it stops. |
Using the pictures in this thread you should easily be able to know if you have SAI. However, the problem you are describing has nothing to do with it.
Poor idling and oscilating RPMs with the K&N intake might be because you still have the SAI intake hole open on the intake pipe. The K&N pipe is the only one that actually has that. |
(Post 2261667)
Poor idling and oscilating RPMs with the K&N intake might be because you still have the SAI intake hole open on the intake pipe. The K&N pipe is the only one that actually has that. well i just went down to my car and checked. i guess i do have SAI. and i also checked the intake pipe and it looks to me like everything is connected. is there anything else it could be?? |
Nothing else that would have to do with SAI. Take it to the shop. And when you do, leave your intake alone.
(Post 2265213)
what do u mean leave my intake alone?? |
(Post 2265852)
Your new intake is flowing much more air through your MAF than your old intake....if you havent unplugged your battery and allowed your car to relearn its fuel trim settings it will do that. It pulls a ton of air in at startup because the intake is much better and then drops the RPMS because its getting too much and then kicks it up and then drops it down while its finding the right fuel trim to get it to the 800rpm idle with so much more air coming in. Unplug the + on your battery for abotu 30 mins and let it reset and then start up your car and let it relearn all the fuel trims for your new intake.... it might take a week or so to get it to stop doing that...but it will eventually either way.... |
(Post 2270550)
No no hold on a sec.....
as a update since i still get asked questions
currently there is NO plan to move forward on the pacesetter header to work with the SAI system |
I don't expect there ever will be either.
Ok, I got my cobalt on saturday and today I come on this board to join and learn a bit and I find out I have this system. I read the post that mrgoodwrench78 had on here thanks to halfcent. Now if i have my technician do this to eliminate the sai I can take all the parts of for it and replace with any that I choose? I do appreciate everyones time and effort on this and sorry If I missed the answer on the other 17 pages I read on this.. :)
