Tom's Build :D
#279
may 6th at 630pm ill be there
vids are here!!!
Dyno vids!!!
vid 1: 3rd gear pull
http://www.youtube.com/watch?v=yvtn2xChKOw
vid 2: 3rd gear pull (best one)
http://www.youtube.com/watch?v=yPUr4hkNm0I
vid 3: 4th gear pull
http://www.youtube.com/watch?v=GHSEFSrR1H8
vid 4: 3rd gear pull speedo shot
http://www.youtube.com/watch?v=RdLib1ah2O4
vids are here!!!
Dyno vids!!!
#281
4th is the other numb in that the 179, it really doesnt matter, cause 3rd is what i did before, dynos are subjective, the real show is what you have improved from, and i have always dynoed on this dyno
#283
ill probly play with the exhaust if anything to get some more free ponies, aft refining should bring it damned close, the dyno owner said he has seen fixing a number that far off gaining it enough to be over 200
#286
lawls...too much blood sweat and tears and monies into the car to want to do that now hahahahaha
i think it could a little bit ya, but theres not a whole lot of point to it, if i shift i get popped right into the powerband where i have a little bit more tq in the next gear and accelerate faster then not shifting
#291
ur car sucked
#292
but i have to get a second engine first (shouldnt be too much from a buddy) and then rip it apart and start...will be a little while, but at least itll be easier
#293
lawl, the next set of mods like that is when i get a second engine, im going to bore it out, build the bottom end, higher comp pistons, remove balance shafts, port and polish the head, bigger valves (if i can lol) springs, retainers, the same cams, more aggressive shaving of the head...ya..ALOT and im going to run race gas
#298
#299
Dude why the hell would you build a 2.2 NA that is such a waste of money you should have done something worth while and turbo'd the damn thing.
what a failure at life!!
