Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.2L L61 Performance Tech (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/)
-   -   transmission fluid (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/transmission-fluid-207674/)
ferrucci86 Mar 12, 2010 06:32 AM
transmission fluid
Whats up, I read the how to on how to change your transmission fluid and it says to use dexron III ATF, The problem i had was all the dexron III ATF was automatic transmission fluid. Do they make a manual transmission fluid like this?
xxxxsh4d0wxxxx Mar 12, 2010 01:17 PM
https://www.cobaltss.net/forums/how-guide-43/how-change-ss-sc-transmission-fluid-112595/
That is for the SS/SC, but same procedure. If you have an F23 with a manual trans, you use the Dexron ATF that corresponds to the year of your car.
I would tell you, but I don't know what year your car is.
