Transmission Fluid tool tip
5 Attachment(s)
I have a 2006 Chevrolet Cobalt LS (2.2L) manual and did my transmission fluid change a couple months ago. Been meaning to post these pictures for a while and wanted to give a helpful tip for those that decide to change their transmission fluid. I know there is a how to, but if you don't want to shave an allen key, I recommend the EZ RED WC100, it allows you easier access to tight spaces and provides better torque for removing that plug... Also helpful if you want to attach it to a ratcheting wrench... anyways included some pictures below for reference.
If you want to replace the lower and upper transmission drain bolt/plug the part number is 93368573. Tool to remove transmission drain plug: EZ RED WC100 Transmission fluid I used Amsoil ATLQT-EA (2 bottles) Attachment 11627 Attachment 11628 Attachment 11629 Attachment 11630 Attachment 11631 |
I had 0 issues using an Allen key personally but this is still a sweet idea/tool and a good share.
Ive been using an allen wrench that i cut super short to fit there. Maybe the base model has less room.
(Post 7613735)
That's a nice tool kit
Those are handy. I just used an allen socket and extension for mine.
https://cimg2.ibsrv.net/gimg/www.cob...7c498c91bf.jpg |
^That doesn't work for the drain plug which is exactly behind the subframe beam.
Originally Posted by exninja
(Post 7613807)
