Using an 04 cavalier engine to build for my 06 l61
You can use any L61 block except the J body crank reluctor wheel is different.so basically you can use the block and would have to use your crank and head.You can try getting a 2007-08 L61 which has gen 2 internals(stronger block,better flowing head,different camshaft profile)you would just have a useless cam sensor chilling on the front as earlier L61's don't have the cam sensor.
ThoR294
10-04-2015 08:44 PM
