Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.2L L61 Performance Tech (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/)
-   -   Vacuum/boost issue (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/vacuum-boost-issue-278479/)
heathkidder May 9, 2012 03:34 PM
Vacuum/boost issue
So at idle or anything my gauge stays on 0 and at wot my boost numbers are all over the place i checked gauge wires all look good and when u start the car the bypass valve pin should go in right? Idk what the problem is and help?
n0xid May 9, 2012 03:57 PM
Leak somewhere.
heathkidder May 9, 2012 04:17 PM
But where all can it leak from
n0xid May 9, 2012 04:32 PM
Intake manifold gasket, any vacuum lines, that kind of stuff. Does the car act funny at all? Could just be a leak by your gauge and nothings really up haha.
heathkidder May 9, 2012 04:33 PM
Im not sure where to check my bypass valve is fine though
heathkidder May 9, 2012 04:34 PM
No acts fine just the gauge acts funny and iv replaced a few hoses just incase but didnt change im gonna email aem maybe its the sensor
heathkidder May 9, 2012 04:37 PM
If i felt around could i find it while its idling
n0xid May 9, 2012 04:43 PM
Would be the easiest way, if it's showing 0 then a lot of air should be hissing out somewhere. As you said it might be the gauge, maybe find a mechanical one to test out.
heathkidder May 9, 2012 04:46 PM
Like one that isnt digital and yea i should have 21-22 vacuum and should hear it if its at 0 i looked the number up on gauge and says its suppost to read boost and vacuum but on paper work doesnt say anything about vacuum
n0xid May 9, 2012 04:59 PM
This is exactly why I don't use the electronic boost gauges, more stuff to go wrong haha. Definitely check around where the sensor for the gauge is though.
06_SIC_SS May 9, 2012 05:02 PM
turn the motor on and let it idle.. spray soapy water over vac lines and points of interest.. see bubbles.. u have a leak
heathkidder May 9, 2012 05:47 PM
30-4406 is the gauge i have isnt it vacuum also? If i had a leak idk why it would remain 0 and not jump around atleast
nhanson May 9, 2012 06:13 PM
it is a vacuum gauge also. where did you tap the line for it? Mine is off of the nipple on the intake manifold.
turdsandwich SS May 9, 2012 06:18 PM
Make a boost leak tester and hook it up to the throttle body and do a test. With the car off pressurize the system and spray soapy water on anything that could leak. Could be injectors seals tb gasket intake manifold gasket. Something's leaking.
heathkidder May 9, 2012 07:09 PM
It was a pain to get the intake off id hope i dont gotta take it off lol im still wanting to blame it on the gauge it should show some type of vacuum why exactly 0
nhanson May 9, 2012 07:44 PM
Your idle is ok?
Start spraying starting fluid around vac lines and such...idle changes then thats where the problem is
heathkidder May 9, 2012 08:56 PM
Ill try sumthin tonight i checked everything and felt around and found nuthin ... Its always the lil things
heathkidder May 10, 2012 03:10 AM
So i took some vids im gonna post up but the damn gauge stays at 4-8 then randomly goes to 0 then when i go wot it goes to 0 and i let off and it shoots to 16 wtf lol
heathkidder May 10, 2012 03:18 AM
http://i816.photobucket.com/albums/z...h_4bb76f47.jpg
http://i816.photobucket.com/albums/z...h_b930c4f5.jpg
Idk why the uploaded side ways lol
heathkidder May 10, 2012 04:38 AM
it was on my fone dk if you can even see it ill have to get a better vid but pretty much the gauge is fuckin haunted
06_ion2 May 10, 2012 09:16 PM
Where did you tap for said gauge?
heathkidder May 10, 2012 09:18 PM
Wher every1 does? I am gettin my gauge exchange they said it could be my sender
06_ion2 May 10, 2012 09:57 PM
I dont know where that is. I guess im different.
heathkidder May 10, 2012 10:17 PM
Right off the mani lol
scagnetti76 May 13, 2012 06:03 AM
Spray minor amounts of propane from a soldering torch around suspected areas while idleing and listen for rpm jump.
