180hp N/A help
180hp N/A help
I have a 2010 cobalt ls and with the 2.2L suppose to have 155HP I am very much happy with the car in the last year. I would like to keep it N/A but bring the HP to around 180. Any help with the parts needed to accomplish this would be a great help. Thanks -Josh
Full bolt on's will get you from 155 flywheel HP to 180 flywheel HP
You will need:
Intake (Injen is a good choice)
Header/Downpipe (Vibrant is a good choice)
Cat Back Exhaust (Magnaflow is a good choice)
We carry all these and much more on www.TurboTechRacing.com
A custom tune should then push you up to that mark.
You will need:
Aaron is correct. Of course its easier to achieve that with LE5 parts so you should consider the LE5 manifold and throttle body. But you're getting into more complex mods if you do so. Shooting high = complicated modding.
I'm gonna make life easier on the OP:
Simple:
Injen Intake
Full 2.5" Exhaust
-Vibrant Header/DP (I use)
-Ark DT-S (I use)
Tune
More Complicated:
2.4 Intake Manifold
2.4 Throttle Body
Cams
Head Port
Valve Springs
Etc..
I have seen 2.4's reach 180whp uncorrected (Dynojet for you dyno nutt huggers) with relative ease.. On a 2.2 you'll need to get into the heavy mods for 180+ to be possible. It will become a time and money pit but whatever floats your boat.
Simple:
Injen Intake
Full 2.5" Exhaust
-Ark DT-S (I use)
Tune
More Complicated:
2.4 Intake Manifold
2.4 Throttle Body
Cams
Head Port
Valve Springs
Etc..
My '06 2.2 made 137 Wheel hp with AEM dryflow cold air, 2.4 TB, 2.4 intake manifold, full SS/SC exhaust, and a tune.
I believe yours already has the TB and intake manifold so that would be a waste of time. Cold air and full exhaust with a good HP tuners tune should make the car real fun to drive.
Your LAP already has the 2.4 manifold, just the revised 2008 version from the 2.4 Sport models but you still have the 2.2 TB. And because it also has similar wiring you can bolt in a 2.4 throttle body without a tune. You have to get the 6-pin 2008 version. I have it on my LAP w/o a tune and it helps on the topend along with my SS/TC catback. Hopefully to tune later
Simple:
Injen Intake
Full 2.5" Exhaust
-Ark DT-S (I use)
Tune
More Complicated:
2.4 Intake Manifold
2.4 Throttle Body
Cams
Head Port
Valve Springs
Etc..
Simple:
Injen Intake
Full 2.5" Exhaust
-Ark DT-S (I use)
Tune
More Complicated:
2.4 Intake Manifold
2.4 Throttle Body
Cams
Head Port
Valve Springs
Etc..
no im asking is it possible to get 180whp on the 2.2 with full bolt ons with cams and valve springs? i have a friend with a 2.2 that we will be doing some stuff to. gonna do full bolt ons with a 2.4 mani and lsj tb. then later do cams and valve springs. just trying to get an idea where we can get him power wise with each of the 2 setups
cammed 2.2 cobalt 1/4 mile 5-14-11 - YouTube
ran a total of 9 times 5-14-11 with a best time of 14.562 @ 96.6mph.
Specs: 06 2.2 cobalt, 5spd, 185shp 165wtq
aem cai
2.4l intake mani
2.4l tb
lsj injectors
head shaved .020"
stg2 comp cams
zzp 78lb valve springs
ottp 4-1 longtube header/ catless downpipe
clear image 3" exhaust w/ magnaflow race muffler
TTR engine and tranny mounts
h&r sport springs
stripped interior
nitto neogen 225/45/17 tires
trifecta tune
Found this and thought of this thread. I don't follow the 2.2L threads much but I hope this helps.
aem cai
2.4l intake mani
2.4l tb
lsj injectors
head shaved .020"
stg2 comp cams
h&r sport springs
stripped interior
trifecta tune
