2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
2009CobaltLT's 2.2LAP SC Build Thread
Old Jun 21, 2012 | 04:40 PM
2009CobaltLT's Avatar
Well, I figured I'd jump on the bandwagon and start a build thread so people can answer all of my questions, as I am sure I will have a lot.
Got my SC kit in the mail yesterday and now I'm even more pumped to get this all installed. First little bit is going to be cleaning and painting the parts, but I will be posting pics as I go. I am definitely going to need help identifying which bolts go where, as I got them all in a plastic bin for the most part.
Last edited by 2009CobaltLT; Jun 21, 2012 at 04:40 PM. Reason: Automerged Doublepost
Old Jun 21, 2012 | 04:46 PM
royce777's Avatar
Pics
Old Jun 21, 2012 | 04:48 PM
I'll upload pics on the first post once I'm off work
Old Jun 21, 2012 | 05:46 PM
Any idea what hub this is?
Think I'm gonna get ZZP S3, might run 2 HE's, still deciding
Any thoughts what injectors/size these are?
Is that the correct core setup for dual pass?
Usable, but probably gonna grab ZZP's dual pass instead
Old Jun 21, 2012 | 10:28 PM
After a little closer look it appears that the injectors are "Deka" brand. Any way to check the flow rate?
Old Jun 21, 2012 | 10:32 PM
nhanson's Avatar
More than likely those are 60 lb injectors.
The hub is too hard to tell.
I run only ZZPs S3 and it works perfectly.
That is correct setup for dual pass.
Old Jun 22, 2012 | 09:30 AM
So it turns out there is a light coat of a bluish paint on the intake mani, came right off when cleaning it with carb cleaner. Anyone have any tips on cleaning this stuff? It's kind of a pain in the ass lol
Old Jun 22, 2012 | 11:19 AM
nhanson's Avatar
Find someone to hot tank it
Old Jun 22, 2012 | 11:05 PM
hhrfreek's Avatar
Get some paint stripper. I used Mar Hyde Tal Strip before and it will wrinkle paint off in less than 2 minutes. Then just spray it off with a hose. Don't get that **** on your skin though it will burn you.
Old Jun 23, 2012 | 11:16 AM
nhanson's Avatar
Spray with carb cleaner and scrub away if you want to do yourself
Old Jun 23, 2012 | 12:20 PM
That's exactly what I did, worked great haha. Painting today
Old Jun 23, 2012 | 02:58 PM
07cobaltguy's Avatar
The injectors a Seimens DEKA 60's, I had them when i was S/C
Old Jun 23, 2012 | 04:21 PM
Allgood Customs's Avatar
nice setup man, looks like that toaster should at least 40 hp, you may even need to swap the pistons out after putting that on
Old Jun 27, 2012 | 01:23 PM
Not sure if I ever posted these up here, but made a dual gauge cluster bezel for my Defi gauges a while back:
Old Jun 28, 2012 | 01:18 AM
^that looks sick man, great choice in gauges, it flows very nicely
Old Jun 28, 2012 | 02:01 AM
brian.olsson's Avatar
that hub looks like the zzp hub, I think I have either a 2.8 or 2.9 that will fit that hub, brand new in the package I believe, hell it might even be a 2.7, I'll have to look when i get home
Old Jun 28, 2012 | 08:36 PM
I think I'm gonna go with a 2.9
More pics, painting is going slow as I'm a little busy recently:
Old Jun 28, 2012 | 08:42 PM
nhanson's Avatar
i have my smoothflow 2.9" up for grabs
Old Jun 28, 2012 | 08:59 PM
This is the pulley I have, still need to figure out what hub I have:
Old Jun 29, 2012 | 03:41 PM
Gonna do some more painting on the SC and TB tonight. Still need to get a dual pass endplate so I can get my IM back together
Old Jun 29, 2012 | 04:12 PM
conerboner's Avatar
that dual gauge cluster looks so nice. it should have came like that
Old Jun 29, 2012 | 04:18 PM
Thanks, I totally agree. Hopefully I can get some LEDs swapped into my gauge cluster to match the Defi gauges. I still want to get the SS gauge cluster though, just cant seem to find one for the 08+
Old Jun 29, 2012 | 06:15 PM
Old Jun 29, 2012 | 06:52 PM
WOW, that's gonna look so nice in there. What kind of paint did you use
Old Jun 29, 2012 | 07:32 PM
Just rustoleum high temp engine paint, good to 500 degrees. Used the same stuff on my valve cover last year and it's held up fine
