2010 cobalt 2.2 wiring harness diagram
im looking for the wiring diagram for a 2010 cobalt 2.2 automatic. mainly the wiring that goes to the cooling fans to fuse panel and then to ecu. trying to trace down a bad wire. i have all the pin info just not the rest thanks
1 Attachment(s)
Attachment 62207There ya go.
Thank you
Kolt's the man hooking it up with schematics.
on the dark green wire going to relay there is a break and reads x101 E. what does the x101 mean? i see the wire running into the body it must connect to something and it must come back out and to pin 5 . trying to chase down a bad wire. any info would be appreciated
pinched wire in loom i found it. thanks again for diagram
x101 is a inline connector between harnesses
