2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
3 codes n was wondering what it could b
Old 04-14-2017, 09:48 PM
bahoodle's Avatar
p0171 - fuel sytem too lean (Bank 1)
P1171 Fuel Trim Cylinder balance
P0300 multiple engine misfires detected
car is a 2009 2.2 with 220,000 miles
Old 04-15-2017, 05:39 PM
bahoodle's Avatar
soo im pretty sure its from a dirty er clogged fuel injector but idk figure id get some input from u guys :P i mean if bank 1s running lean and it has a fuel trim cylinder balance code id assume that would cause the misfire since one cylinders not getting enough gas but enough spark so its not combusting right but yea u guys think that its a fuel injector issue? thanks for any help/ suggestions
Old 04-15-2017, 08:19 PM
4 cylinders only have bank 1. It's in reference to cylinder banks so a v8 has 2 banks of 4 cylinders.
As far as the codes goes, start with checking your plugs, and compression before you go guessing a injector problem. That would have a misfire on a single cylinder not random. Without looking at data coming off a scanner it's had to say.
Old 04-16-2017, 11:14 AM
bahoodle's Avatar
ive got oil on the 2nd plug from the left on the coil boot side so im thinking i gotta replace the valve cover gasket :/ also the airbox has a heavy coat of oil in it :/ anyways im gonna do a compression test tomorrow n hopefully everythings ok
Old 04-16-2017, 08:38 PM
I'm sure something is tired with 220k, depending on the OCI and the UOAs it could be nearing the end of life for the engine
Old 04-18-2017, 09:49 AM
jdbaugh1's Avatar
Like ECaulk said you should read your spark plugs and look for variation. Not on my car but on a truck I own I have had lean conditions caused by a dirty restrictive fuel filter combined with a fuel pump on it's way out. The spark plugs may indicate if it is a problem in a single cylinder (like a dirty injector) or with all cylinders (possible low fuel pressure).
bahoodle (04-18-2017)
Old 04-18-2017, 10:20 PM
bahoodle's Avatar
yea my codes went away after tightening intake bolts valve cover bolts messin wit o2 sensor cables anyways im gettin it inspected once my steering shaft gets here but after that im gonna check the compression n hopefully they're all close to 120..... lol
Old 04-18-2017, 10:21 PM
bahoodle's Avatar
n the plugs all looked the same aside from oil on one of em on the top side of the plug but the cylinders were all really clean looking which i thought was weird :/
Old 04-19-2017, 11:00 AM
jdbaugh1's Avatar
You tightened the intake manifold bolts?vvYou think you had a vacuum leak that was causing lean condition?
Hopefully your compression is is much higher than 120 lol.
Old 04-19-2017, 11:20 AM
I'm going to guess the vacuum leak caused that lean condition.
Def hope the compression is higher than 120, even on an engine with 220k.
Old 04-19-2017, 07:01 PM
bahoodle's Avatar
yea it was only running rough on a cold start so i checked that all the bolts were tight and they weren't lol it had a leak from the dp to resonator the bolt heads rusted completely off so i fixed it wit some ghetto flange things that force it back together but the codes are gone which is nice :P jus gotta put my intermediate shaft in n the car will be flawless for 200 miles til something else breaks lol
Old 04-19-2017, 07:07 PM
bahoodle's Avatar
and i could'nt remember what it was supposed to b 150 on a n/a and 180 a turbo i think idk ill post back to this once i do it im just waiting for a guy at work to bring me his gauge
