Engine build!
#52
Well she runs! Only issue is it wont restart once its warm so tuning adjusting hopefully.
I picked up a new chain today...compared my old chain to new chain and it was stretched.
Im SO happy.
https://www.facebook.com/photo.php?v...92729195578846
Im SO happy.
#56
Heres a short pull...leans way out on top end like high 12s.
This is part throttle.
https://www.facebook.com/photo.php?v=10153163106085022
#64
Was running great...then a bearing spun.
New plan is Im getting a stock motor to throw in for now and then taking my built motor and redoing it properly.
Im thinking since I never took the crank out and didnt balance it, thats what caused the failure.
So today I pulled off everything on the intake side.
The life of a racecar.
I found a 20k mile motor near me for $600.
Setup will be 2.8 pulley on E85 just like before. I just wont do any high load pulls
#65
#73
are your actuators locked? the biggest issue i had after messing with my timing was locking the gears so i had bad valve train noise and my vvt would kick in funky. if you need help PM. im rarely on here anymore since im stock
#74
Well I had the engine ALMOST tore down but then said **** it and bought $30 bearings to try this again. Luckily only intake side was off and some coolant drained.
I reassembled the top end and yanked the bearings out and put freshies in.
Couple things I learned:
1. Not correct assembly lube - dont ask...
2. Bearing locks/tangs not correct - they are supposed to be same side and opposite sides.
Just waiting to fill her with oil and fire it up! Its nice having friends who are AMSoil dealers
