LAP Mechanical Specs
Metric
English General Data Engine Type Inline 4 Cylinder Displacement 2.2 L 134 CID RPO LAP, LE8(E85 Compatible, HHR) Letter (VIN) F Bore 85.992-86.008 mm 3.3855-3.3861 in Stroke 94.6 mm 3.727 in Compression Ratio 10.0:1 Balance Shaft Bearing Clearance 0.030-0.060 mm 0.0012-0.0024 in Bearing Diameter - Inside - Carrier 20.050-20.063 mm 0.7894-0.7899 in Bearing Diameter - Outside - Carrier 41.975-41.995 mm 1.6526-1.6534 in Bearing Journal Diameter 20.000-20.020 mm 0.7874-0.7882 in Bushing Clearance 0.033-0.102 mm 0.0013-0.0040 in Bushing Diameter - Inside 36.776-36.825 mm 1.4479-1.4498 in Bushing Journal Diameter 36.723-36.743 mm 1.4458-1.4466 in End Play 0.050-0.300 mm 0.0020-0.0118 in Block Balance Shaft Bearing Bore Diameter - Carrier 42.000-42.016 mm 1.6535-1.6542 in Balance Shaft Bushing Bore Diameter 40.763-40.776 mm 1.6048-1.6054 in Crankshaft Main Bearing Bore Diameter 64.068-64.082 mm 2.5224-2.5229 in Cylinder Bore Diameter 85.992-86.008 mm 3.3855-3.3861 in Cylinder Bore Out-of-Round - Maximum 0.010 mm 0.0004 in Cylinder Bore Taper - Maximum 0.010 mm 0.0004 in Cylinder Head Deck Surface Flatness - Transverse 0.030 mm 0.0012 in Cylinder Head Deck Surface Flatness - Longitude 0.050 mm 0.002 in Cylinder Head Deck Surface Flatness - Overall 0.08 mm 0.0031 in Camshaft Camshaft End Play 0.040-0.144 mm 0.0016-0.0057 in Camshaft Journal Diameter 26.935-26.960 mm 1.0604-1.0614 in Camshaft Thrust Surface 21.000-21.052 mm 0.8268-0.8252 in Connecting Rod Connecting Rod Bearing Clearance 0.029-0.073 mm 0.0011-0.0029 in Connecting Rod Bore Diameter - Bearing End 52.118-52.134 mm 2.0519-2.05252 in Connecting Rod Bore Diameter - Pin End 20.007-20.017 mm 0.7877-0.7881 in Connecting Rod Side Clearance 0.070-0.370 mm 0.0028-0.0146 in Connecting Rod Straightness - Bend - Maximum 0.021 mm 0.0083 in Connecting Rod Straightness - Twist - Maximum 0.04 mm 0.0157 in Crankshaft Connecting Rod Journal Diameter 49.000-49.014 mm 1.9291-1.9297 in Crankshaft End Play 0.050-0.380 mm 0.0012-0.0150 in Crankshaft Main Bearing Clearance 0.031-0.067 mm 0.0012-0.0026 in Crankshaft Main Journal Diameter 55.994-56.008 mm 2.2045-2.2050 in Cylinder Head Overall Height, Minimum 128.9 mm 5.07 in Surface Flatness - Block Deck - Transverse 0.030 mm 0.0012 in Surface Flatness - Block Deck - Longitude 0.050 mm 0.002 in Surface Flatness - Block Deck - Overall 0.1 mm 0.004 in Valve Guide Bore - Exhaust 6.000-6.012 mm 0.2362-0.2367 in Valve Guide Bore - Intake 6.000-6.012 mm 0.2362-0.2367 in Valve Lifter Bore Diameter - Stationary Lash Adjusters 12.013-12.037 mm 0.4730-0.4739 in Lubrication System Oil Pressure - Minimum - @1000 RPM 344.75-551.60 kPa 50-80 psi Oil Capacity 4.8L 5.0 quarts Piston Rings Piston Ring End Gap - First Compression Ring 0.20-0.35 mm 0.008-0.014 in Piston Ring End Gap - Second Compression Ring 0.35-0.55 mm 0.014-0.022 in Piston Ring End Gap - Oil Control Ring - Rails 0.25-0.75 mm 0.010-0.030 in Piston Ring to Groove Clearance - First Compression Ring 0.04-0.08 mm 0.0015-0.0031 in Piston Ring to Groove Clearance - Second Compression Ring 0.030-0.069 mm 0.0012-0.0027 in Piston Ring to Groove Clearance - Oil Control Ring 0.058-0.207 mm 0.0023-0.0081 in Piston Ring Thickness - Upper First Compression Ring 1.170-1.190 mm 0.0461-0.0469 in Piston Ring Thickness - Upper Second Compression Ring 1.471-1.490 mm 0.0579-0.0587 in Piston Ring Thickness - Oil Control Ring - Rail - Maximum 0.473 mm 0.0186 in Piston Ring Thickness - Oil Control Ring - Spacer 0.929-1.006 mm 0.0366-0.0396 in Pistons and Pins Pin - Piston Pin Clearance to Connecting Rod Bore 0.007-0.020 mm 0.0003-0.0008 in Pin - Piston Pin Clearance to Piston Pin Bore 0.004-0.012 mm 0.0002-0.0005 in Pin - Piston Pin Diameter 19.997-20.000 mm 0.7873-0.7874 in Pin - Piston Pin End Play 0.210-1.266 mm 0.0083-0.0498 in Piston - Piston Diameter - @14.5 mm up 85.967-85.982 mm 3.3845-3.3851 in Piston - Piston Pin Bore Diameter 20.002-20.007 mm 0.07875-0.7877 in Piston - Piston Ring Groove Width - Top 1.23-1.25 mm 0.0484-0.0492 in Piston - Piston Ring Groove Width - Second 1.52-1.54 mm 0.0598-0.0606 in Piston - Piston Ring Groove Width - Oil Control 2.01-2.03 mm 0.0791-0.0799 in Piston - Piston To Bore Clearance, without polymer 0.010-0.041 mm 0.0004-0.0016 in Valve System Valve Lifters - Valve Lifter Diameter - Stationary Lash Adjuster 11.986-12.000 mm 0.0005-0.0020 in Valve Lifters - Valve Lifter-to-Bore Clearance - Stationary Lash Adjuster 0.013-0.051 mm 3.2210-3.2299 in Valve Springs - Valve Spring Load - Closed - @32.5 mm 245.0-271.0 N. - Eng Spec. Valve Springs - Valve Spring Load - Open - @22.5 mm 525.0-575.0 N. - Eng Spec. Valves - Valve Face Runout - Maximum 0.04 mm 0.0016 in Valves - Valve Seat Runout - Maximum 0.05 mm 0.0020 in Valves - Valve Stem Diameter - Intake 5.955-5.970 mm 0.2344-0.2355 in Valves - Valve Stem Diameter - Exhaust 5.935-5.950 mm 0.2337-0.2343 in Valves - Valve Stem to Guide Clearance - Intake 0.030-0.057 mm 0.0012-0.0022 in Valves - Valve Stem to Guide Clearance - Exhaust 0.050-0.077 mm 0.0020-0.0026 in © 2008 General Motors Corporation. All rights reserved. |
Very nice man. :thumb: So only the HHR version (LE8) is flex fuel? OR will the LAP be also?
BTW...I nominate first sticky of this section. |
Also, with tuning could the LAP or L61 be used with E85?
Originally Posted by kkanowitz
(Post 2969189)
Originally Posted by umrdyldo
(Post 2969238)
bump for maven
What exactly are the major differences betweent the L61 and LAP?
Any at all or just new code for minor improvements? Nevemind. I found the thread that infos in... |
Originally Posted by RedBaseBolt
(Post 3297808)
Any at all or just new code for minor improvements? GM tends not to hand out new RPOs for minor upgrades. Every 2.2L gasoline ECOTEC without VVT from 2000-2009 is called an L61, there have been numerosu small changes and an entirely new block, head, ignition system, multiple fuel system, etc, etc.... |
damn. and I thought GM changed the name because it used a new head gasket. ;)
