2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
lsj throttle body wiring
Old 06-14-2018, 01:02 AM
Sharkey's Avatar
im buttoning up a supercharger setup on our shops 2009 hhr and ive run into issues on the throttle body wiring. there is so much conflicting info i cant figure out whats correct. i found a diagram on how to wire the lsj throttle body and its way off and nothing works.
does anyone have a throttle body wiring diagram for a 2.2l LAP? if i have that i could sort it out (ive got reliable diagrams for the lsj stuff), but i cant even find a diagram i reliably know is from an LAP.
thanks
Old 06-14-2018, 09:53 AM
Kolt's Avatar
LAP Throttle Body connectorThrottleBodyConnectorEndView.pdf
LAP Wire diagram
Old 06-14-2018, 01:24 PM
Sharkey's Avatar
exactly what i need, thanks.
now if i could just sort out the injector tables for the gm stage 2 injectors id be set.
Old 06-14-2018, 01:30 PM
Kolt's Avatar
no prob, you'd have to ask someone else bc im not a tuner AT ALL.
Old 06-14-2018, 03:05 PM
Sharkey's Avatar
i think i got it sorted, at least i hope. found someone on hp tuners forum that had an 09 cobalt lap with a supercharger and the gm stage 2 42lb injectors, so i just copied his tables.
all else fails ill go back to stock injectors, the car is flex fuel so it has 36lb injectors stock. might be marginal for what im doing (3.1 pulley) but i can always try it and see how it goes.
Old 07-21-2018, 06:35 AM
Crav3's Avatar
As long as you are using the same injectors the injector data should be the same and you will be running fine. If you need any help let me know, I supercharged my LAP G5 and tuned it myself. Been using HPtuners software for about 3 years now and am pretty familiar with it
Old 07-21-2018, 01:37 PM
Sharkey's Avatar
i got it sorted out a while ago. i ended up using the 42lb injectors and the injector data i had found worked.
the thing rips, i was actually pleasantly surprised how fun that car is now.
Taylor89
10-10-2018 10:16 AM
bobbob160
06-10-2015 09:00 AM
redcobalt07
11-20-2010 04:03 PM
csa1982
Canadian Mid West
10-15-2010 04:14 PM
bubba_jay
10-13-2010 07:26 PM
Quick Reply: lsj throttle body wiring
