M62 Install on 2.2LAP (XFE Remix)
hey i have made a plug to seal the map sensor hole in the top of supercharger if you arent going to be using it here is the link to what i made.
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/need-plug-m62-map-sensor-216924/
Ya, this junkyard is about an hr away...but ya...at least they have some balts.
PM replied
That is very nice looking. I will consider this!
https://www.cobaltss.net/forums/showthread.php?t=216924
#36
When I was piecing together a kit, I bought a kit off someone that included alot of random stuff. I'd look for a kit and go from there. If you try to piece it all together individually, it'll probably take many years..
But good luck. haha
But good luck. haha
#37
Today I purchased:
Intake manifold, LSJ TB, LSJ dipstick tube, and the coolant fill tank (with cap and upper hose)
I will update the first post once the items have arrived.
#39
Today I picked up the LSJ IC Pump Insulator, LSJ Lower Intake Manifold Mount, LSJ Bottom Intake Manifold End Plate To Intercooler Pump Outlet Hose, LSJ Rear IC Pump Bracket To Intake Manifold Mount bolts.
#42
Some parts arrived today :bigsmile: Thanks Bryan!
Intake manifold, Throttle body, coolant reservoir with cap, upper hose, & bracket, and the LSJ dipstick tube!
#49
I have some misc stuff laying around if you're looking for anything else and I'm pretty local. Check my FS thread posted in my sig and I'll see if I have anything else. Good luck!
#50
LSJ TB connector
Hi guys i'm doing a ZZP 2.2/2.4 superchager kit and cannot figure out how to make the 8 pin LSJ TB connector work for my 2.2 LAP harness with 6 pins. I see it's been posted before but i keep getting confused. How do i repin the connectors to make it work. please
