Need help ASAP!!!!
I need the size of the three bolts that connect the header to the downpipe and where to get them. All 3 of badmabs broke >:(
contact brad from badmab and he'll send you some more
just grab some bolts and start test fitting. you dont have bolts and nuts an washers around ur house?
I believe that it's 13mm
Posted from Cobaltss.net App for Android |
I'm not using badmabs bolts again, plus I need them ASAP.
Don't have thicker ones laying around the house. Thanks Dan |
My only help to give is my header never came with studs, so re-using the OEM ones caused them to cross thread and shear. 1 is still good and not cross threaded. The other 2 I just drilled the hole bigger and nut and bolt with a lock washer those 2. A full year later and no leaks. (went back to OEM gasket also)
Do these headers just suck? I have read several threads with people having issues with them (cracking, bolts breaking, etc). I was going to purchase one off ebay but they sound iffy.
I used the bolts that came with the badmab header. So far this is the only issue I have had, so I can't say that it's a shitty header
