New Engine P0365 Cannot Relearn HELP PLEASE
Just swapped a 09 HHR 2.2 into a 09 Cobalt LT. P0365 is the only code. I have searched for info everywhere, but there is nothing that I can do to fix this. My scan tool is a Verus if that is any help. Car has a hard time starting at times. I cannot relearn the CKP due to DTC. Cannot monitor VVT solenoid actuation due to DTC. From the limited info I have read that this could be a mechanical issue, but with 14k on replacement engine I feel that is unlikely.
The ECM does not receive 4 camshaft pulses within 3 s i would check for open or high resistance
Checked for camshaft signal. Exhaust had no signal through scanner. I went to back probe sensor when I realized it was not plugged in. Stupid mistake? Maybe so, but because of Cleanxfe's post I was able to diagnose and solve the issue without wasting any more time. Thanks a lot!
sweet glad i could help out
