steelmesh |
03-11-2019 07:43 PM |
This is from my 2006 LE5 engine, so take with a grain of salt:
CIRCUIT/SYSTEM TESTING FOR DTC P0171- Allow the engine to reach operating temperature. With the engine running, observe the Long Term FT parameter with a scan tool. The value should be less than approximately 20 percent with the engine running at operating temperature.
- If the value is not less than 20 percent , inspect for the following:
- With the ignition ON and the engine OFF, observe the manifold absolute pressure (MAP) sensor parameter. The MAP sensor pressure should be within the range specified for your altitude. Refer to Altitude vs Barometric Pressure.
- If the MAP sensor does not indicate the correct barometric pressure, refer to DTC P0106. See: P0106
- Vacuum hoses for splits, kinks, and proper connections
- Low fuel pressure
- Fuel contamination
- Properly functioning fuel injectors
- Missing, loose, or leaking exhaust components from the HO2S forward
- Vacuum leaks at the intake manifold, the throttle body, and the injector O-rings
- The air induction system and the air intake ducts for leaks or for a missing air filter element
- Evaporative canister purge lines plugged or obstructed
- The crankcase ventilation system for leaks
- The HO2S for proper installation and for electrical wires or connectors that may have contacted the exhaust system
- The HO2S signal circuit open, shorted to ground, or shorted to the low reference circuit
- Malfunctioning engine components
Your baro is off by 1 psi for Omaha Nebraska checked as of now, but I assume you took the snap shots at a different time. Still, if Sensor 1 is reading lean, then by golly the ECU will throw fuel at it, you can see this in the fuel trims. You may have to get down and dirty, continuity check the O2 wiring between the connector and the ECU, and check all those wires for a short to ground. You'd be surprised...
REPAIR INSTRUCTIONS- Air Cleaner Assembly Replacement
- Air Cleaner Element Replacement
- Air Cleaner Outlet Resonator Replacement
- Evaporative Emission (EVAP) Canister Replacement
- Evaporative Emission (EVAP) Canister Purge Solenoid Valve Replacement
- Evaporative Emission (EVAP) Canister Vent Solenoid Valve Replacement
- Evaporative Emission (EVAP) Hoses/Pipes Replacement - Canister/Fuel Tank
- Evaporative Emission (EVAP) Hoses/Pipes Replacement - Chassis
- Evaporative Emission (EVAP) Hoses/Pipes Replacement - Chassis/Canister
- Fuel Hose/Pipes Replacement - Chassis
- Fuel Injector Replacement
- Fuel Pump Fuel Feed Hose Replacement
- Fuel Pump Module Replacement
- Fuel System Cleaning
- Fuel Tank Draining Procedure
- Fuel Tank Filler Evaporative Emission Pipe Replacement
- Heated Oxygen Sensor Replacement - Position 1
- Manifold Absolute Pressure (MAP) Sensor Replacement
- Throttle Body Assembly Replacement
Doesn't mention post-cat O2. I'd be interested to find out the logic behind the post-cat O2 causing a major lean running condition. My understanding of the fueling strategy is that if the O2 is reading lean, it will enrich the A/F mixture to compensate.
