rewiring zzp TB harness?
I'm in a bit of a pickle. I purchase zzp's 6 to 8 pin throttle body adapter to do an le5 TB swap on my lap. I think i may have goofed as it seems the adapter is meant to convert to an lsj throttle body (am I right?).
I plugged it all up turned the key and had nothing at all going on under the hood not even a starter which I believe means that the PCM can't see the throttle body and won't take any action. Either that or I have a dead 2.4 TB.
So in theory all I have to do is rewire the adaptor to match the way I need it to for an lap to le5 swap correct?
I had seen some schematics for the wiring swaps on the forum but I can't find them for the life of me now. Also does it matter that the TB is from a Pontiac g6? Or is the TB wiring the same as on the 2.4 ss??
Thanks for any help!
I don't have the answers you're looking for (sorry), but if you've seen them before, your best bet if nobody gives an answer is to go to google and search "cobaltss.net le5 tb swap" or something similar; the search function on this site is kind of a joke.
