2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Stock 2.2 Dyno Baseline
Old Jan 25, 2009 | 01:01 PM
unijabnx2000's Avatar
09 Cobalt XFE
What can be said about my numbers?
you can see this is run#2, run 1 was 138hp, and run 3 was 125hp. WTF?
Old Jan 25, 2009 | 01:04 PM
Perfect.disguise's Avatar
138WHP is rather high.....
Old Jan 25, 2009 | 01:35 PM
how is it high when it's supposed to have 155hp @ crank
Last edited by unijabnx2000; Jan 25, 2009 at 01:35 PM. Reason: Automerged Doublepost
Old Jan 25, 2009 | 03:03 PM
jpunishment's Avatar
sounds about right are you a 5 speed or auto
Old Jan 25, 2009 | 03:04 PM
5 speed!
Old Jan 25, 2009 | 03:08 PM
hatrickstu's Avatar
its because your license plate is upside down
Old Jan 25, 2009 | 03:10 PM
GTPAUL's Avatar
You were getting heatsoaked after the first run...not exactly new news
Old Jan 25, 2009 | 03:11 PM
Blackout06LS's Avatar
Sounds about right.
Old Jan 25, 2009 | 03:12 PM
normally you lose about 10-15% if your manual and 15-20% if your automatic i think im not 100% sure but a baseline L61 rated at 145hp crank 5 speed normaly dynos 133hp
Old Jan 25, 2009 | 03:26 PM
FASTL61's Avatar
check your fuses!your HP fuse must be blown
Old Jan 25, 2009 | 04:09 PM
time to remove it then
already did, no luck couldnt find it
i figured, going to have to do something about better cooling.
Last edited by unijabnx2000; Jan 25, 2009 at 04:09 PM. Reason: Automerged Doublepost
Old Jan 25, 2009 | 04:12 PM
was going to see if that cool additive for radiator helped.
and i was going to do the intake baffle removal.
Old Jan 25, 2009 | 04:31 PM
ive tried Redline's water wetter in my car and after a whole bottle it only dropped a degree or 2 of highway driving its more effective on people running straight water in there cooling system
Old Jan 25, 2009 | 05:16 PM
but running straight water and WW dont give you any antifreeze protection
Old Jan 25, 2009 | 05:37 PM
no you would only do it in a race car or only run it in the summer then switch back before it gets cold
Old Jan 25, 2009 | 05:39 PM
good point, but i'd hate bleeding the air out everytime
Old Jan 11, 2010 | 02:19 PM
Some new numbers
Last #'s were @ 5k miles
These are @ 23k miles.
Only changes since then are tint, battery, oil change.
run 1 on the graph is from original dyno.
**Time for tune** as you can see my AFRs are going crazy rich for N/A past 4.5k rpm
compared to last time & it being OEM tune.
Last edited by unijabnx2000; Jan 11, 2010 at 02:20 PM. Reason: Automerged Doublepost
Old Jan 11, 2010 | 02:26 PM
umrdyldo's Avatar
IS that dip in the AFR due to PE Delay?
A tune is gonna net you a lot of horsepower throughout the RPM range.
Old Jan 11, 2010 | 02:38 PM
whats PE?
Old Jan 11, 2010 | 02:47 PM
umrdyldo's Avatar
whats PE?
Power Enrichment. Look at the AFR.
When the car is at full throttle for more then a few seconds, it adds more fuel to try and increase the power and help protect the engine.
It also saves gas by not using so much for the first few seconds.
When you get tuned most will turn off PE delay so that you will have richer AFR every time you go full throttle.
Old Jan 11, 2010 | 02:50 PM
I dont know, wont until my tuner hooks up to the ECU to tune it.
Just from his exp b4, he said it was probably doing it b/c the ECU went into closed loop mode
Old Jan 11, 2010 | 02:56 PM
umrdyldo's Avatar
PE delay is always present in a stock Cobalt.
What you have going on is exactly normal.
Old Jan 11, 2010 | 03:03 PM
it thats normal then its stupid. going 10:1 afr on an N/A engine!
and if you look at 1st post the afr curve is a bit different and that didnt dip under 12:1 afr
Old Jan 11, 2010 | 03:31 PM
springerdesigner's Avatar
numbers seem fine.
Old Jan 11, 2010 | 07:41 PM
Maven's Avatar
It looks lke its only going to 11:1 to me, but that aside, this is perfectly normal. Its a failsafe, its so you dont grenade the engine running lean at high load/high rpm
