Supercharge LAP
I decided to finally go SC instead of TC, dont flame about TC being better because i know it is for hp number and etc...
My question is how much power can the stock internals handle on the '10 2.2, Ive read about 350WHP(ish) turbo'd Gen-II blocks. But I was curious if anyone knew how much more? Also will the stock exhaust have to be replaced? Im doing a cat delete hopefully this weekend, if that makes a difference. |
I'd suggest atleast a 2.5" exhaust. Not sure what is on yours right now tho
About 250 HP on the internals (rods).
For best flow get header, downpipe (2.5"), cat-back (2.5") |
You can stay stock exhaust (cat removal is a huge help), but there's no good reason to. A nice aftermarket exhaust like the GMPP that sounds clean and flows way better than stock will help out quite a bit.
You won't make 300+whp on a blower setup anyway, so you shouldn't have internal problems. I'd suggest keeping it under 15psi as that seems to be the good safe limit for the current crop of boosted 2.2/2.4 guys, but if it was me i'd just pound it til it gave up, then put some pistons/rods in it when you get to that point. |
Only reason I asked is because this way i can get the blower on before the snow comes and dont have to worry about exhaust right away. Dont want to go drop a huge amount of money right away on the car.
250 on stock internals
I've setup a ZZP turbo kit on a 2.4 with stock cat-back, it works just fine.
Originally Posted by strykr
(Post 6006849)
Post pix of what?
Oh, bought a M90 SC today for a total of $200, gonna throw that bad boy on the car!:p |
(Post 6007751)
Post pix of what?
Originally Posted by nhanson
(Post 6007944)
M90 wont work
You bought wrong blower
good price for a m90 tho
M90 can work, takes a ton of work though, ask 100%meth about it. I've run stock exhaust on the mp62 with a small pulley, its real damn quick but still you're leaving a ton of power on the table.
i messaged him, its the mp90 (newer gen of the m90) that he used. But there are builds on the internet of people putting m90's on the L61 2.2's..
it's not a newer gen
the mp90 is magnuson's version of the m90. |
Originally Posted by ItalianJoe1
(Post 6006907)
Anything will help, but if you put a real exhaust on the car it will help more.
Gave up on the m90, going to try to sell it now. Hopefully end up finding myself a cheap m62 afterwards.
250hp tops.
250whp orrrr 250 crank hp?
I dyno'd 271whp on my LAP currently under boost (turbo)
ZZP 2.2L Stage 3 Turbo Kit.... TIAL BOV & Wastegate... Trifecta Tune... Hahn Intake... Streetrace Intake Manifold... 2.4L TB... Catless DP... 3" Cat-Back... Forged Block |
Originally Posted by LtDanBoostdG5GT
(Post 6414521)
Keep in mind that the "250 HP" test was done with NITROUS (which is a harder hit than boost).
People see 250+ whp and are fine. Some even 300 whp but thats getting dangerous. |
