wtf???
#57
so... i just ordered my new spark plugs and should have them around 1pm pacific time (2.5 hours from now) which i hope will fix the problem.... i do remember on the side of the plugs i put in for my build were the LSJ one's i believe, i havnt pulled them out yet, but im still trying to figure out why the plugs i have now will suddenly make my car run so shitty?
#58
Nice to finally prove to someone that the vendors on here are raping people on prices of parts....seriously ottp 38$/sparkplug....what a rip off
#59
so i swapped out the spark plugs, and that fixed my idling problem...... i took it out and it still fucked up for a second but went away (i was pushing it a lil to see what would happen).... shes running fine right now as long as i dont go into full boost, ive cleaned the maf and its just drying right now but holy crap it was dirty!
what i got
what i had compared to the new
what i got
#61
seems to be working nicely, but im kinda scared to push it to see if it does it again..... im wondering if it could be because of my shitty tune too
#62
i changed my injector seals today and my interceptor went from reading 8-20 misfires per cycle at idle down to 0!!!! thats right, 0. zero. and when i decelerate it was reading as high as 44 misfires. today the highest i saw was 4. i know that the interceptor is not even close to 100% accurate, but it gives you the idea. Rough idle is pretty much gone, one or two more updates on my tune and they should be gone.
CLIFFNOTES: if you didnt change your injector seals when you put in your larger injectors, give it a shot. it made a difference for me.
#64
like 25 through rock auto. do your research though, i forgot i had aftermarket injectors so only my bottom 2 o-rings fit. maybe email zzp and see if theyll sell you ones that fit the stage 2 injectors? im sure they have some laying around
#67
AAARRRRGGGGGHHHHH!!!! Car ran beautifully this morning, went to go for lunch and im still havig the same problem! Im getting mad missfires in cylinder 1 (9) and 3 (13) the plugs are gapped at 0.038 is this correct?
