[Build Thread- Twincharged LE5] Brand new engine has milky gunk inside
Old 06-21-2017, 05:13 PM
  #101
advise's Avatar
Never noticed any noise at start up on mine
same dead quite
Old 06-21-2017, 05:17 PM
  #102
Henry3959's Avatar
Nice.... That definitely leaves room for heat expansion.
Old 06-22-2017, 03:00 PM
  #103
Henry3959's Avatar
Do you have posted somewhere why you went with a Supercharger in addition to the turbo? I won't bore you with reposting if you already have and / or have learned more recently.
I'm just looking at the HP the supercharger takes (which isn't anything near a 50HP 6-71) as compared to its benefits once your turbo is spooled up. Then at that point is the supercharger restrictive.
Old 06-22-2017, 04:27 PM
  #104
The sc isnt restrictive, its basically an airflow multiplier. It creates more exhaust gasses down low to help spool the turbo and after that its just along for the ride basically. At no point is it a restriction though.
Old 06-29-2017, 12:51 AM
  #105
Everybody knows if you wanna swap ecus you have to swap the body harness with it right....right?!
Not if youre me...
Old 06-29-2017, 01:01 AM
  #106
Got an 07 2.4 SS Automatic harness from a junkyard. I deleted all of the auto stuff, AC stuff, rear O2 sensor, etc..
Finally got one of the blue body side connectors for an LE5, all labeled here
Disassembled my original body side connector (07-08 L61 and 08 LE5)
Lucky for me, since the harnesses are both 07, the wire colors and circuit numbers are the same. So once i took the time to label everything, all i had to do was depin the LE5 body side connector and replace the wires with the pins from my original body side.
Also did some extra clearancing for my 3.8" pulley.
All im waiting on now is a clutch alignment tool because i seem to have misplaced mine, should be running very soon.
Old 06-29-2017, 07:20 AM
  #107
Awesome man keep it up
Slowbalt2000 (06-29-2017)
Old 06-30-2017, 12:38 AM
  #108
Harness done besides being rewraped
Read the file with hptuners so at least some of my wiring is right
Old 06-30-2017, 09:19 AM
  #109
jdbaugh1's Avatar
Did you go over why you are having to adapt a different ecu or what exactly are you doing there? Sorry if I missed it.
Old 06-30-2017, 09:36 AM
  #110
user 72239's Avatar
Because Adam is a masochist
Slowbalt2000 (06-30-2017)
Old 06-30-2017, 09:55 AM
  #111
qfe
Old 06-30-2017, 11:59 AM
  #112
I didnt like how it was set up before being an 07 car but overlaying an 08 file on the computer. It always had weird issues with engine power reduced and stuff. Plus i just wanted to see if i could do it, pretty straight forward actually. Hopefully it will run better than ever.
Old 06-30-2017, 12:14 PM
  #113
As long as you can keep the motor running for more than 100miles you'll likely find out
Old 06-30-2017, 12:22 PM
  #114
No promises
Old 06-30-2017, 02:02 PM
  #115
jdbaugh1's Avatar
I'm all for you getting knowledge on swapping ECUs. Me being an 06 base model that is something I need to seriously consider.
Old 06-30-2017, 02:13 PM
  #116
It really isnt hard at all, helps to have all the wiring diagrams when i need them. Let me know if you want help.
Old 07-08-2017, 01:00 AM
  #117
Well the car runs and drives pretty well
Old 07-08-2017, 08:50 AM
  #118
About damn time
Old 07-08-2017, 10:24 AM
  #119
Originally Posted by ECaulk
About damn time
Easy to keep your car running when its basically stock
Old 07-08-2017, 10:25 AM
  #120
Yup its my daily.
  #121
My daily just has an intake
Old 07-08-2017, 10:28 AM
  #122
Eventually I'll get a different daily and the lnf can get racecar status
Old 07-08-2017, 10:30 AM
  #123
2.4 ss
Old 07-08-2017, 10:44 PM
  #124
1966tbird's Avatar
Far Out
Old 07-08-2017, 11:00 PM
  #125
Vids of car running or it didn't happen
Quick Reply: [Build Thread- Twincharged LE5] Brand new engine has milky gunk inside
