2.4 w/oil cooler to 2.4 w/o oil cooler
I have a 2006 cobalt with a 2.4 w/oil cooler, does anyone know if I can install a 2.4 w/o oil cooler. Thanks
dont the manuals have the oil coolers?
I have a automatic with 2.4 with oil cooler, just wondering if I could install a 2.4 with out oil cooler as they are cheaper and readily available.
Did you ever put in that engine without the oil cooler? i have a manual that had one but finding engines with an oil cooler is almost impossible and way more expensive
Originally Posted by webster8004
(Post 7665099)
You will just need a lower radiator hose and a reservior hose from non oil cooler model.
Originally Posted by Nabalt2.4
(Post 7665224)
yeah you can delete it pretty easily.
The tstat housing is the same, it's not like lsj's from what I understand and from what I've seen on my motor which is an le5 with oil cooler out of an hhr.
(Post 7665240)
It's set up like the lnf if I learned correctly. Basically there is a t fitting in the lower radiator hose and then a t fitting in the upper oil cooler hose.
The t fitting in the radiator goes to the lower oil cooler hose. https://cimg9.ibsrv.net/gimg/www.cob...4d62c91e2c.jpg The t fitting in the upper oil cooler hose goes to the coolant reservior. https://cimg2.ibsrv.net/gimg/www.cob...8b19216bc8.jpg |
So I would be able to delete the oil cooler use the existing hoses (if long enough) and still use the t fitting for the reservoir? Or could I run the reservoir straight to the t stat housing in the oil cooled housing?
| All times are GMT -4. The time now is 01:06 AM. |
