anyone install an oil pressure gauge in thier 2.4?
if so....could you tell me if you just throw away the factory harness that goes to the factory oil pressure sender. And how big of an adapter do i need for the aftermarket sender unit if its already 1/8"
you have to plug the factory sendor to a different spot. i plugged it in at the top by the valve cover on the drivers side. i would check summitracing dot com for the adapter.thats where i got mine
Originally Posted by hailcesar75
(Post 4057040)
could you please take a pic of where you put your factory sensor? And you put your aftermarket sensor in where your factory one was right? And also could you tell me how you wired the wire to where you put the factory sensor come on ppl please! 29 views and only 1 response..i need help here |
Shoot, I didn't use an electrical. Got mechanical. But I have a electric water temp and the instructions were there with the auto meter gauge. Gimme a sec and I'll take a pic
here you go..... birds eye view, sorta.... https://www.cobaltss.net/gallery/fil...0/img_1034.jpg see, its right behing a stock harness...find the plug right there. its a bitch to get off... https://www.cobaltss.net/gallery/fil...0/img_1036.jpg thats were i put the stock oil pressure plug |
