anyone use them for regrinding cams
Besides, the issue is not re-inventing the wheel with our car's, its the VVT and the centerlines and how they will behave when the cams move with a bigger camshaft. The VVT tables are optimized for the way the stock cams are, changing that profile without changing the VVT tables seemingly screws up the way it works. When I switched to the LNF exhaust cam, even though the profile was very similar, I had to make adjustments to the intake VVT table to actually see those improvements because the exhaust cam centerlines were different from stock. Not as simple as coming up with a profile for say a LSJ.
as for choices for the 2.4 there is none cam wise no blanks to be had either i may try them and see whats the worse that cam happen i have swap stock cams back in
no one confirmed it either way
it would be pointless to swap in bigger cams and think you wouldent have to mess with the vvt tables
Yamaha uses a 5 valve head on a few of their motorcycles. 3 intake valves 2 exhaust valves. I wonder if this will be common soon to have 5-6 valves per cylinder.
Sign_Something
13
09-26-2015 11:44 AM
