Battery Sparking, Crackling and Hot!
Hey everyone. So over the weekend I installed the S/C kit from ZZP, got the computer back, and was hooking up the battery to start her up. I put the positive cable on first and then the negative and as soon as the negative touched the terminal it started sparking and melting the terminal.
I immediately disconnected and began to check every single connection, including the grounds, the alternator to starter connection, EVERYTHING. I went to try it again and the exact same thing happened. Today a buddy and I were trying to figure out if there was a short.... This is where it gets weird! We have disconnected the entire fuse box after removing each individual fuse to find the short. I completely pulled out the alternator and disconnected everything on the starter. When we went to check for a short (I have the little light with the needle deal and put the ground terminal on and connect the clip to the + cable and touch the + terminal) the light still comes on! We pulled the 120 amp fuse right off the battery and it still does the same thing!!! Please, can someone, anybody shed some light on the situation?! This is my daily driver and is obviously very important to get running soon. I am not the most electrical savvy, but if you point me in the right direction I'd be so very grateful.... Any thoughts????? :confused::cry: |
Check where you grounds are placed..
(Post 7616910)
your battery is in backwards and you are putting the + to the ground cable
Originally Posted by JapEatr
(Post 7617004)
Keep the ideas comin though... |
could you have mixed up the large ground cable that bolts to the trans by the starter and the B+ cable(S) to the fuse box?
(Post 7617007)
Sounds like possibly something is back feeding
Originally Posted by no_ss
(Post 7617053)
So for craps and giggles we decided to hook the battery back up...No arcing issues!!! So we started installing everything as if whatever it was worked itself out. When we went to hook the battery back up, again, sparking crackling and all that. What gets me is I take the short circuit tester and the light still lights up, meaning that there IS a short.... Could it be a bad positive wiring harness? Like the whole thing??? Need as much help as I can get on this one... Oh and no fuses are blown. Lastly, when we disconnect the two grounds that are bolted to the side of the block (one from the wiring harness, the other to the frame) we don't have the arcing issue AND all my interior stuff comes on! From the radio to the door chimes and trunk lights.... :wtf: :confused: |
Start taking things you think it may be off and keep connecting the battery. Can't really tell what it is
(Post 7617391)
https://cimg3.ibsrv.net/gimg/www.cob...5f088c811.jpeg The little piece of metal on the starter solenoid cable, the little piece of metal at the end of that rubber boot was touching the now metal intake manifold! What threw us off is we disconnected it twice! Checked it and everything! It wasn't until taking off the intake manifold we were able to see that just a piece of that hot wire to the starter solenoid was shorting out on the manifold!!!! Took apart the entire car to find just that little piece! Good advice no_ss!! :twothumbs |
Glad you found it! Now you can have fun with your car lol
So im pretty sure i fried my computer... ZZP has been hardly any help. Its like theyre givin me the cold shoulder after ive already spent a few thousand dollars on their parts. First they were cool, now theyre cold.
After getting the short issue solved, got everything assembled, tightened, triple and quadruple checked every part, connection, vaccuum line, you name it it was checked. And the car fell flat on its face. Long story short, pretty sure the computer is fried. It keeps popping up P1682, which is Driver 5 Line 2, replaced the Starter Ignition Switch, checked the wires for any shorts, checked for loos connections and this code keeps popping up. There was a post from a trifecta dealer that was having the same issue. Anyways, followed what they did on their post and determined i have a bad ECM/PCM. So i ordered a new ECM on eBay and the seller is not sure if its for a 2.2 or a 2.4? Emailed ZZP about it and they said that they dont guarantee it will work and to find a different ECM or else will have to pay for another tune on another ECM. What are your guys' thoughts, will a 2.2l ECU be ok if flashed with 2.4l factory settings and then tuned????? |
Didn't see you have an LE5, make sure it's a computer for the LE5.
(Post 7617941)
