Boosted LE5 1/4 Mile Record?
Posted this in General Cobalt as I thought I would get a better response..but apparently not. So posting it here now.....
Hello,
Anyone here know the answer to this?
Is it ZZP's run of 11.83@113.78mph from their website? The drag race times thread has my 13.3 all-motor run in first place...so thats no help.
Anywho, hopefully someone knows.
Thanks!
Hello,
Thanks!
Yes, when my car was all-motor it went 13.3@99, its a LE5/LSJ Hybrid tho that is in my Sunfire...not a Delta car.
I have since turbo'd the car and it now runs 12.0@115mph on 15psi.
I am assuming ZZP does hold the record then with their 11.8??
I can't at the moment, my meth nozzle would have to be increased to go any higher. The motor is around 11.3:1 compression. So its a challenge to keep the knock away, currently running a 7gph nozzle and 91 pump. Also, this motor makes around 222bhp, so 15psi goes a lot farther than on a 174bhp car.
It is 5speed, Getreg F23, Quaife diff, Bully stage 3 6-puck clutch disk, stock pressure plate, stock axles.
