Can the LEA block be re-sleeved?
This looks like a very easy process with the proper Kent-Moore tool.
https://www.youtube.com/watch?v=BtsVlj3n-OQ
I'm working with Jeffrey already on how to solve this. Both the Diamond pistons and LEA block are from him. and I have .005" PTW in the virgin part of the block and cylinder 4 has .0072 at the top without touching it. #4 has .0022 taper which is why I am thinking about relining it.
Slobodan Miloević
Only the gen 1 and 2 blocks have the replaceable sleeves that use the Kent moore tool.
The gen 3+ blocks have non pressed in liners that are "non serviceable". Rencently, people have started machining out the liners and retrofitting pressed in sleeves to the gen 3 block structures.
It's doable, yes. But it's not as simple as pressing out the old sleeves and installing new ones
jdbaugh1 (04-21-2018)
It’s possible but not even Trevor jolley likes to do it. And he makes sleeves. There’s barely any material in to work with. I have the LEA block in mine and I wouldn’t bother sleeving it. It can hold a lot of power without them.
07blackg5 (05-10-2018)
No...
The 1.082 compression height and .010 off the deck puts that pistons back to the same height and squish. Diamond's dish is a meager .020" at the center with soft edges to aid in a more efficient burn only. The .010 off the head wasn't in my plans but I have decided to stick with the OEM gasket. With the effective volume of -3.0cc we are calculating a 10:1 CR with plenty of room for additional valve lift in the larger reliefs. If this wasn't a VVT engine I would have changed the cam timing. It's still a fair weather DD. Actually been enjoying driving the H2 again.... just not washing the beast.
Remember I'm at an air pressure disadvantage here at 6000'+ ASL
Let me ask you a question. I have a 2012 Chevrolet Equinox 2.4 there is a LEA unit. Can I replace the sleeves on it, or is it 3rd generation and is not repairable? If a block needs to be bored, where can I buy a piston and rings with the appropriate oversize? Thanks for any information!
Are the LEA engine blocks definitely not repairable?
In this case, give a link to a site where you can buy pistons and rings oversized after boring the cylinder block. Thank.
