Code PO172 Help
Code PO172 Help
So I keep getting this dang code system too rich bank 1. Replaced upstream O2 sensor, fuel injectors, spark plugs, MAF, cleaned the throttle body too. Any suggestions on where to go from here would be much appreciated. Starting to think a professional diagnosis is in order. Help!
I am just go a throw this out there but you try replacing ur evap valve in ur engine bay? Or the one in ur carbon Box...the one under the hood is cheep the one in the back cost more because you have to bye a new wire harness....just sayin because of open loop and closed loop is evap.
My car wouldn't start after putting gas in it...had to crank it like three times to get it to start if I remember correct the code was p0172 but not sure I replaced both just to make sure never had a problem after.
Well, I took the Balt to the best tech I know and let him know of the problems and parts that have been replaced. He gave me an oh crap look and said it won't be today. Hoping for the best...
OrangeCoba
09-25-2015 06:06 PM
