Found some junk in the oil pan.
Old Aug 14, 2016 | 12:04 PM
Jason McDaniel's Avatar
I got a 2007 SS N/a 2.4 I am the origional owner and never had the engine broke apart.
It's been blowing oil like a powerstroke, fouling plugs and going into limp mode. and with a compression trail from left to right of 80, 95, 130, 130. I figured it's time for a overhaul.
I pulled the valve cover intake electrical ect. Then went for the oil pan before removing the chain and head and found this plastic bracket and a bolt in the bottom. The crank side looks good I can't find nothing Broken, piston oilers are all there is have no clue what this is.
Old Aug 14, 2016 | 12:53 PM
Timing chain guild.
Old Aug 14, 2016 | 03:09 PM
ItalianJoe1's Avatar
Yeah your front timing chain guide broke. Most likely you have some lightly bent valves. I'd pull the head and carefully inspect everything, odds are it's off timing and has been for a while now.
dufcobalt
Show & Shine
Sep 14, 2019 07:47 PM
slobalt2367
Mar 14, 2016 03:35 PM
SS4speed
Feb 28, 2016 07:04 PM
SSMiKE8
Feb 26, 2016 06:10 AM
