JBP VVT LE5 Camshafts
Old Dec 5, 2006 | 08:34 PM
  #276
g5mike's Avatar
well could have had the car tommorro,but headbolts are required,so Ill pick em up tomorro and Ill have the car finally on Thursday
Old Dec 5, 2006 | 08:37 PM
  #277
victory_red_SS's Avatar
LSX RWD S/C conversion
I think Mike has lost his ha ha, over this endeavor.
Old Dec 5, 2006 | 08:38 PM
  #278
g5mike's Avatar
2 thousand later! you're right I lost my ha ha.
Old Dec 5, 2006 | 08:40 PM
  #279
Is your buddy still welcome at your house?
Old Dec 5, 2006 | 08:51 PM
  #280
g5mike's Avatar
accidents do happen,cant be mad about it,I have been more upset with the long wait it caused,cant wait to go play in a few days though
Old Dec 5, 2006 | 08:54 PM
  #281
Looks like your getting your ha ha back.
Old Dec 5, 2006 | 08:55 PM
  #282
g5mike's Avatar
that and one heck of a valvetrain too!
Old Dec 5, 2006 | 09:03 PM
  #283
Brandon97Z's Avatar
good to hear mike. You got a list of everything you had done in the past month or so?
Old Dec 6, 2006 | 08:16 AM
  #284
g5mike's Avatar
Its a list I want to forget
Old Dec 6, 2006 | 11:08 AM
  #285
Brandon97Z's Avatar
haha
Old Dec 6, 2006 | 04:15 PM
  #286
g5mike's Avatar
I think that in a few days a new thread should be started for these camshafts, cause this thread has been destroyed
Old Dec 6, 2006 | 06:02 PM
  #287
Brandon97Z's Avatar
A few days? It better be tommorow
Old Dec 6, 2006 | 06:08 PM
  #288
g5mike's Avatar
my headbolts will be in at 10.00am tomorro, Ill take it to the shop and they said after that is only the timing,so Friday morning Im gonna go have lottsa lottsa fun!
Old Dec 6, 2006 | 06:13 PM
  #289
Brandon97Z's Avatar
Good news man, that thing's gonna haul. You still gonna get it tuned or have all the surprises emptied the mod money?
Old Dec 6, 2006 | 06:22 PM
  #290
g5mike's Avatar
Im hoping that I dont have to have this tuned in(which would be good news for us 2.4 guys) but I will dyno the gains though,I will tune the car in once the header/dp is on,which I could have easily done already if it was not for the mess
Old Dec 6, 2006 | 06:41 PM
  #291
Brandon97Z's Avatar
I'm thinking of getting ride of my c/a header so hit me up when you looking for one
Old Dec 6, 2006 | 08:22 PM
  #292
IonNinja's Avatar
so what happened again?
Old Dec 6, 2006 | 08:40 PM
  #293
g5mike's Avatar
A friend demolished my valvetrain, sending all this into a downward tailspin
Old Dec 6, 2006 | 08:49 PM
  #294
Brandon97Z's Avatar
First post on 10-23 "Mike is in the middle of installing the camshafts!" .....its now 12-06.......day 44......
Old Dec 6, 2006 | 09:02 PM
  #295
8cd03gro's Avatar
lol!
i feel for all you guys waiting for the results...on oone of the mustang forums the first guy to install heads has dynoed, but can't post the dynoes, track times, or anything until the company that built them approves...but of course he gave us a little vid from inside the car just to tease us...its been like 3 weeks waiting and he already has the dyno IN HAND. GAH!
Old Dec 6, 2006 | 11:26 PM
  #296
HiSpdPursuit's Avatar
im still skeptical about the fact you are not going to tune the car with them. If they work out without tuning that is awesome...if not... new valvetrain or worse...
Old Dec 7, 2006 | 01:23 PM
  #297
LewiSS's Avatar
The tune doesn't effect "hard parts." It only re-programs the computer (fuel injection amount and timing, ignition timing, etc.). So lack of a tune will not hurt the "valvetrain or worse."
The new cams should improve air flow, and as long as the flow isn't more than the MAF limits, the stock computer (stock "tune") should be able to compensate. Where you get into issues is if the injectors are too small, and the computer is running them at 100 percent duty cycle to try to get enough fuel into the cylinders to go with the added air flow (remember, the cams can only increase or decrease air flow into the cylinders). This is the scenario when tuning Gen I and Gen II Neons. Different engine designs tend to have different issues.
One aspect of the 2.4, however, is the variable valve timing. As long as the cams allow the valves to physically clear the top of the pistons at both timing positions, the only thing a tune can do is move the RPM where the cams are advanced/retarded.
None of this is to say that a tune wouldn't be benificial, only that the only real issue not having one can cause is a lean or rich condition. And the worst case scenario of that is a hole in a piston (if lean) or so much fuel it actually washes down the cylinder wall and pollutes the oil and causes wear. But neither issue is instantaneous, and drivability usually make it clear if either is happening.
-J-
Old Dec 7, 2006 | 06:48 PM
  #298
panblackrose's Avatar
Wow, good one lewiss my man
Old Dec 7, 2006 | 06:55 PM
  #299
g5mike's Avatar
Indeed!
Old Dec 8, 2006 | 12:16 PM
  #300
Mr.Z's Avatar
Mike... today is friday. When I get back from work tonite, i expect to see some results. But hey then again we have been watching this thread for who knows how long? Im just hopeing its worth the wait. For your sake and ours
