JBP VVT LE5 Camshafts
Old Dec 17, 2006 | 06:11 PM
  #451
UpOnGaMe's Avatar
Originally Posted by g5mike
Track is closed right now but when I have the header/dp,balance shafts,boredTB and the tune done then I'll get some track numbers
whats a balance shafts sorry,?
Old Dec 17, 2006 | 06:18 PM
  #452
pjk91's Avatar
oh yea, he has a patriot head too.
balance shafts are necessary when raising the redline
Old Dec 17, 2006 | 06:57 PM
  #453
g5mike's Avatar
It also takes away rotating mass, it frees up about 10-12 hp and its advertised as something thats good for your engine
Old Dec 17, 2006 | 07:43 PM
  #454
UpOnGaMe's Avatar
where can this be found?
Old Dec 17, 2006 | 08:02 PM
  #455
avro206's Avatar
looking forward to some track times. You don't have a stock time do you?
Old Dec 17, 2006 | 08:10 PM
  #456
victory_red_SS's Avatar
LSX RWD S/C conversion
Just remember that neutral balance shafts will cause some vibrations.
Old Dec 17, 2006 | 08:13 PM
  #457
REDFOCZ's Avatar
Man the balance shaft delete kit for the ecotec is expensive as hell
Old Dec 17, 2006 | 08:17 PM
  #458
I think calling it a "delete kit" lead people to a misunderstanding. The shafts are being swapped for different ones and the cost for 10-12 hp seems reasonable.
Old Dec 17, 2006 | 08:20 PM
  #459
REDFOCZ's Avatar
Sorry I'm still thinking like a focus owner. The balance shats are deleted on the duratec motor thats why i called it a delete kit
Old Dec 17, 2006 | 09:02 PM
  #460
g5mike's Avatar
gm carries them,my tech at the dealership was saying these things are great for the engine and you get rid of weight and get some ponies,is it true, he also said" it gets your revs up quicker"??
Old Dec 17, 2006 | 10:58 PM
  #461
8cd03gro's Avatar
well if it lessens rotating mass, your motor will be able to accelerate faster meaning faster revving.
Old Dec 17, 2006 | 11:02 PM
  #462
Red07SSNA's Avatar
The balance shafts in the ECOtec engines are installed to counter the natural vibrations of a 4-cylinder engine to make it run smoother. The negative side is that they are weighted -- thus require horsepower to turn. They are timed/phased with the engine via the timing chain.
Neutral balance shafts are light-weight replacements for the weighted shafts. They require less horsepower to turn (they free-up, rather than create, horsepower). the negative side is that the engine vibration is greater.
If you drive your car 98% of its' life on the street and race it 2% of its' life on the track it probably would not be worth the extra horses to put up with the extra vibration.
Old Dec 18, 2006 | 12:10 AM
  #463
panblackrose's Avatar
What was the price to have the cams and shafts installed? what was the price for them overall? where can I get them? Im excited as hell, because i finally plugged into HPTuners and upped my rev limit to 7K, but im still running stock cams and springs. There is so much power in the top of 2nd and 3rd just by adding that extra 200 rpms! I cant wait to see what better cams and a limit of 8K will do!
Old Dec 18, 2006 | 06:50 AM
  #464
jeweler54's Avatar
i wonder if gm would install these?????? if so ill be getting mine in a couple of weeks if not sooner, im calling today.
Old Dec 18, 2006 | 09:01 AM
  #465
g5mike's Avatar
never had to tune them in, they work like a charm, but tooning will only make them better, if you have a raised rev limitor you might want to consider valve springs so you dont chance a valve floating, to have cams installed 2 bills.
Old Dec 18, 2006 | 09:03 AM
  #466
g5mike's Avatar
anyways took the car up to 5500rpms and holy **** it scared me, iwas travelling along and decided to step on it I was going 100kms and when I stepped on it, I was not expecting the power put out,really freaked me,I had to put the other hand on the steering wheel.LOL
Old Dec 18, 2006 | 09:27 AM
  #467
I am sorry Mike, you may not be a good candidate to ride in my car when she's done, or at least not without a couple of prozac and a Depends on.
Old Dec 18, 2006 | 10:09 AM
  #468
UpOnGaMe's Avatar
what was the offical install time on the cams? or more or less how many hours?
Old Dec 18, 2006 | 10:24 AM
  #469
8cd03gro's Avatar
this has probably been asked, but are these regrinds or have blanks been released by gm?
Old Dec 18, 2006 | 10:50 AM
  #470
Allshot's Avatar
Good Ol' depends
Old Dec 18, 2006 | 01:43 PM
  #471
GTP's Avatar
GTP
dynos? Mike?
Old Dec 18, 2006 | 01:45 PM
  #472
kingg5's Avatar
ooo pick me pick me ill do it ill kill people to go for a ride in ur car when its done and im only minutes away in coquitlam..not like that mike guy whos way in delta....:P
Old Dec 18, 2006 | 01:46 PM
  #473
kingg5's Avatar
i think he has jbp cams.
Old Dec 18, 2006 | 02:06 PM
  #474
Cobalt Mav's Avatar
I'm not sure if this is a repost but what is the highest that you rev the engine to before you start cracking rockers or messing up springs or what not?
Old Dec 18, 2006 | 02:18 PM
  #475
jerryg's Avatar
what if you have a ecu flash already will it benefit it better. how much were the cams
