JBP VVT LE5 Camshafts
Old Feb 24, 2007 | 09:23 PM
  #651
UpOnGaMe's Avatar
I third it
Old Feb 24, 2007 | 09:44 PM
  #652
g5mike's Avatar
Originally Posted by mike25
because its a mustang dyno
this tends to be true,except for my case,the last dyno I had done was 155whp on a mustang dyno but the guy could not tune my car.that being said,Forcefed dyno is not a mustang dyno and that other 2,4 put out 122whp,so much for the mustang dynos being lower.Now down the street where that same 2.4 went he dynoed 50 more hp that would put that 2.4 172 on kenetics mustang dyno.What I'm getting at is everyone ragged on me when I put down 155whp on that other dyno(mustang) I thought those were pretty good numbers,now I might only put out 150 on my up comming dyno but compared to the other 2.4 that went in with full boltons and got 1222whp and me not having full boltons if I get 150whp than it will show quite a difference from mine to this other 2.4
Old Feb 25, 2007 | 12:57 AM
  #653
LewiSS's Avatar
The only validity in any dyno run is to compare it to previous runs on the same dyno with the same car. Look at my numbers - as HP goes, it was disappointing, but the increase with the GMPP and scoop is certainly real enough. I had the luxury of establishing a baseline on a dyno that I will use for all future mods. This will give direct comparisons.
If your car would have done 155 on the dyno I used, as compared to the 124 or so my 2.4 did stock, then that would be 30 HP for the cams, which is REALLY GOOD! Unfortunately, direct comparisons are difficult across different dynos, as you point out. Have you seen stick 2.4 numbers from the same dyno that you did 155 on? That would get closer to a direct comparison.
Old Feb 25, 2007 | 06:53 AM
  #654
g5mike's Avatar
no I have not,far as I know the other place I dynoed had not seen a 2.4,that being said,at least I have something now to compare my car to,except the other 2.4 that put down 122 had more mods than I
Old Feb 25, 2007 | 10:38 AM
  #655
UpOnGaMe's Avatar
Did they say they would be able to tune?
Old Feb 27, 2007 | 07:21 PM
  #656
panblackrose's Avatar
I did 150 hp and 148 ft tq on a dynojet, bone stock with 87 octane on a hot day. if that helps with the comparison at all. then on a mustang dyno, my friend's SS/SC with stage two and a few extras put down 225 hp.
Old Feb 27, 2007 | 07:32 PM
  #657
8cd03gro's Avatar
well you can't really compare numbers online with a mustang dyno as it is VERY adjustable, so results will be pretty different from each one. A dynojet is quite a bit more consistant from dyno to dyno.
Old Feb 27, 2007 | 07:59 PM
  #658
I plan on going back to that exact one once i have the injectors and tune next week to see what difference from stock it makes. Then Ill add the intake, dyno, and then the exhaust and dyno. I want to show what our cars can do and also have the info for others.
Old Feb 27, 2007 | 08:26 PM
  #659
8cd03gro's Avatar
good plan, it is always best to go back to the same dyno in comparable conditions
Old Feb 28, 2007 | 03:22 PM
  #660
g5mike's Avatar
I'm gonna have to rescedule this guys for a week later,the dealer ship cant get me the sensor and injectors that I fouled till next thursday
Old Feb 28, 2007 | 03:27 PM
  #661
Matty's Avatar
I thought you were selling?
Old Feb 28, 2007 | 03:29 PM
  #662
g5mike's Avatar
found a way to keep both,I'll buy a truck when I get back east
Old Feb 28, 2007 | 03:32 PM
  #663
Matty's Avatar
Selling your bum on the side now?
Old Feb 28, 2007 | 03:56 PM
  #664
g5mike's Avatar
I been having to make extra money for mods by having sex with senior citizens,those old ladys pay well
Old Feb 28, 2007 | 04:50 PM
  #665
Matty's Avatar
Better than the guys?
Old Mar 4, 2007 | 10:01 PM
  #666
mike25's Avatar
so uh exactly when should we look for some dyno result....**** man im lookin to buy these an nothing to justify power gains yet.... ....and what happened with your injectors?
Old Mar 6, 2007 | 09:28 PM
  #667
mike25's Avatar
bump...any updates?
Old Mar 16, 2007 | 04:22 PM
  #668
g5mike's Avatar
the injectors were fixed last week but as of last night, I busted a rocker roller AGAIN, had to call the dyno shop at the last minute and they are pissed! the dealership cant crack the car open till Tuesday to see if its the same number two intake rocker roller again or maybe more than one...****** BS
Old Mar 16, 2007 | 04:32 PM
  #669
JohnnySasakiMGS's Avatar
<=( I was just saying to my g/f that I would just do cams instead of a turbo to save $. Let down... again. I hope things eventually smooth out for your poor car.
Old Mar 16, 2007 | 04:33 PM
  #670
8cd03gro's Avatar
wow...this is just a **** storm. i feel bad for you man, i have never heard of anyone having this many problems, especially going n/a....usually you go all motor to save yourself from the problems forced induction will bring later on, but you are just getting screwed over and over.
Old Mar 16, 2007 | 04:36 PM
  #671
victory_red_SS's Avatar
LSX RWD S/C conversion
Mike your car is possessed. Shoot it now, and buy that truck.
Old Mar 16, 2007 | 04:41 PM
  #672
g5mike's Avatar
the dealership is trying to say that the second lobe is allowing the rockerroller to float causing the damage, i will know for sure about this on Tuesday or for the cams sake lets hope its just a bad lifter causing this,either way,I almost blew the top half of my engine for a third time.all I can say $$$$$ keeps on costing me,could have bought a turbo set up and a half by now.LOL
Old Mar 16, 2007 | 04:43 PM
  #673
8cd03gro's Avatar
what are the specs on the cam?
Old Mar 16, 2007 | 05:08 PM
  #674
IonNinja's Avatar
so what has JBP had to say about this? since it's probably scared everyone away from touching these cams
Old Mar 16, 2007 | 05:12 PM
  #675
Red07SSNA's Avatar
If you're under the valve cover again put the factory cams back in!!!!
