JBP VVT LE5 Camshafts
Mike, if the shop your dealing with has any concerns or questions about timing feel free to have them call me.
Let me know if you need parts. If you are going to wait 2 weeks for parts to come from michigan, I can next day air them as I have pretty much everything to do a head swap in stock.
Gee, sorry for the bad news, Mike. But there's an upside.
If the head has to come off and at least a couple valves are out anyway, it sounds like time for some primo valve springs so you can bump up the rpm safely! It's much cheaper to do it now than later. Maybe JBP will make you a great price on some springs so you can test and eval. both products together.
Maybe even a mild port and Polish while you're at it.
What do you say guys?
Come on, you know you want it!
Originally Posted by g5mike
that would be sweet sushidog, but that money I dont have(dont know price.btw) but I really dont think there is any thing wrong with the valves, cause the car was never started up
I hate to be the bearer of bad news, but you can bend valves easily by cranking the engine over with the starter. A bent valve, even so slightly, is a garbage valve and won't seal during a leak-down test. If you are ever in doubt with timing, it should be tested by turning the engine over by hand prior to dry starting...
****! if Im going to need new valves, how much???
while your in there just start putting pistons, rods, springs, what else..........nah just messing man but hope all is best case senerio......
before you're talking about bent valves, are the 2.4s intereference or non-interference engines when you have the JBP cams in em? cause thats something to consider before going on a fact finding mission and taking the head off.
Originally Posted by GTP
I think a complete set of installation instructions should accompany these cams and springs. I mean at the very least copy the FSM section and attach it.
Mike...go punch your buddy..
Mike is our tester and mentioned that he had someone "competant" to do the install. We did offer full instructions for install.
At any rate, we include with our camshafts an outline the tools necessary for the install, how long it should take a competant mechanic/shop to perform the install and Pack up their cams and to take it to a competant license mechanic or performance shop. We DONT want customers who have an "idea" of what to do, to do the installation of cams.. Take it to the pros', to avoid exactly what Mike is going through...
You need two specialty tools when installing springs and camshafts. You also need a fair amount of understanding of engine operation when installing camshafts for any engine. Even seasoned mechanics can make mistakes with the best of instructions.
Well Im trying to take the positive out of the fact that some of my valves might be going to heaven and that is.If I have to buy new valves at least JBP sells better one than the existing stockers
At any rate, we include with our camshafts an outline the tools necessary for the install, how long it should take a competant mechanic/shop to perform the install and Pack up their cams and to take it to a competant license mechanic or performance shop. We DONT want customers who have an "idea" of what to do, to do the installation of cams.. Take it to the pros', to avoid exactly what Mike is going through...Great support JBP. I wasn't implying that you didn't offer install instructions, but I am glad to see that you did!! Also that you rent the valve spring tool is exxcellent
been following this thread for a lil while lots of problems..it always sucks used to run into random problems like this too but as always a lil determination goes a long way good luck with everything mike im eager to hear the results
LSX RWD S/C conversion
Originally Posted by Jackalope
Damn Mike you need to punch your friend at least once for every bent valve! Its only fair I say.
Originally Posted by Brandon97Z
I think he said in another post that his buddy bent a valve(s) when they tried to install the cams.
