hitmanws6 |
05-11-2012 01:26 AM |
just installed my intence control arm bushings
took me about a 1:45 min to do the job after pulling the rims off i pulled the 4 bolts that hold the control arm in place.pulled the control arms out used a flat spaid air hammer and the old bushings pushed out. then pressed in the new intense racing bushing in !!! what a difference !!! next on the list are shocks looking at the lnf shocks from crate engine depot with new shock mounts.
so far i have added a zzp down pipe and did a quick tune on the car with hp-tuners drop in k&n air filter and racetronics fuel pump i had left over from my ws6 before i got a sumped tank. and a Harris speed works wet kit jetted to 75 horse with a 15 lbs bottle and ngk tr55 plugs. so far the car is a blast to drive almost more fun then my trans am because you would never expect this thing to run as good as it does.
how do i post pics ??
