misfire??
misfire??
Car has a slightly rough idle and the dealer said my p300 is a old code. My question is, with full bolt ons with no tune would it be the cause?? Thx
110k
2007
Manuel
Ive replaced the clutch already and master cylinder twice.. if that helps.
Intake, throttle body, header/dp, exhaust, flywheel
Try swapping around coil packs and see if its coil pack related. Just unplug the cylinder that's misfiring and swap it with another. See if the misfire follows that pack.
Check spark plugs and make sure they're not old as heck, fouled and are gapped properly, .044"? I believe?
Also, you mentioned throttle body as a bolt on. Are you tuned for a different throttle body?
Sean Cummings
03-09-2018 12:26 AM
Getaway_Driver
09-08-2015 09:41 AM
