K&N Typhoon or Injen CAI for 07 2.4 ss
Anyone know which one would be better or are they about the same?
Any input will help im just starting mods and really have no idea where to start! All the car has right now is aero turbine exhaust tip.
I've got a k&n kit sitting at my house right now if you're interested? Was on the car for about 3 months but I'm doing work and thinking about changing to something different. If you're interested let me know.
theres no way a 3" pipe with a filter on the end can cause more restriction than a corrugated pipe with a huge plastic box on the end.
don't hate, but look at the specifics for the test. big humidity and temperature change between the 2 runs.also,look at the days almost a year apart.and are those numbers at the crank? i also noticed the air fuel ratio, huge difference there...went from 14.99 to 9.6. 2.4's run really rich. if you can tune it more lean, you could get those numbers running stock intake
any ways i have K&N ftw
Same CF though, SAE. If anyone is wondering, SAE correction factor is used to show dyno numbers as if they were made at 29.23 InHg of dry air and 77 F. This is so numbers like this can be compared on different days as they will assume the same conditions, despite different actual "day of" weather conditions.
K&N i love mine had it more than a year no problems great sound. cant speak for the injen i here a lot of good things about them too either way im sure u will be happy with it.
I own the K&N. Don't have any Dyno results. Just my own expierence/ pleasure of using it. Only thing I really noticed was the difference in sound. Makes the care sound meatier at wide open throttle. But if you want to be quite all you have to do is drive normal.
