Needing new spark plugs
Old Aug 14, 2015 | 07:27 PM
Robles14's Avatar
What would benefit me the most if I decide to switch over to premium fuel only.? Already need new spark plugs.
Old Aug 14, 2015 | 07:37 PM
Stock
Old Aug 14, 2015 | 07:40 PM
No benefits of going to premium fuel with N/A
Premium fuel will help clean your engine i believe. With a tune on 93 and a few bolt ons you could gain 20-30hp
Old Aug 14, 2015 | 07:49 PM
Robles14's Avatar
What should I do if I decide to get the Stage 2 Hahn turbo kit down the road?
Old Aug 14, 2015 | 08:01 PM
Once you get that turbo on then yeah use premium
Old Aug 14, 2015 | 08:39 PM
Robles14's Avatar
so right now that i have it stock i should just keep it with regular gasoline?
Old Aug 14, 2015 | 08:42 PM
I would
Old Aug 19, 2015 | 06:31 AM
mtbrent's Avatar
Umm bad advice here. 2.4 is designed to run on premium and will pull timing with regular until its no longer knocking. Sure it runs on regular, but you are down on power.
Old Aug 19, 2015 | 07:20 AM
Staged07SS's Avatar
Administrator
Administrator
Correct.
Stick with the stock plugs. They are good.
Old Aug 19, 2015 | 12:28 PM
My bad then 2.4 is a totally different engine then
Old Aug 19, 2015 | 12:45 PM
Staged07SS's Avatar
Administrator
Administrator
The 2.4 was considered a H.O. engine, and had the same instructions as a stock SS/SC in terms of fuel.
Old Aug 19, 2015 | 12:54 PM
exninja's Avatar
Premium doesn't clean your engine. It's all about that knock yo. As said before, if the ECU pulls timing then you're down on power.
Old Aug 20, 2015 | 03:25 PM
Robles14's Avatar
Thanks everybody very useful info
Old Aug 24, 2015 | 02:10 AM
Ecotecftw's Avatar
This is news to me as well. I've always ran mine on 87octane. Guess I'll start throwing 93 in her.
Old Aug 24, 2015 | 04:59 AM
In a way I believe it does. Part of the reason it costs more is because of the detergents and lubricants they add to it.
Old Aug 24, 2015 | 09:33 AM
Kolt's Avatar
Not really, it all depends on the fuel carrier. Octane rating does not depict detergent ratings, whether or not the fuel carrier is apart of the Top Tier Program does though. The attachment is a bulletin from gm that has a list of Top Tier Stations as of July.
Document ID_ 4225054.pdf
*edit: Kinda hard to see the list, this link will take you straight to the toptier website which has
the list also. Top Tier Gasoline
Old Aug 24, 2015 | 01:05 PM
Ecotecftw's Avatar
That's good info, thanks for the list. I'll stick to those places from now on.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
