Sodium filled LNF exhaust valves in LE5 head?
My goal is to upgrade the exhaust valves on my LE5 build because force induction, I think the best value would be to use the sodium filled LNF exhaust valves, but not 100% confident they will work.
1) Supertech GEVN-0010 shows it fits all ecotec applications: https://www.supertechperformance.com...-exhaust-valve
The dimensions provided by Supertech show:
3) Someone on ZZP asked a product question if they will fit the LE5, ZZP moderator answer the question NO: https://zzperformance.com/ecotec/cam...ec-valves.html
Any insights here?
- Head Diam: 30.1mm(Std)
- Stem Diam: 5.96mm
- Length: 101.5mm
Any insights here?
steelmesh (12-01-2017)
After catching some possible viruses I was able to get this off the old ecotec build book for our reference which shows all valves are the same dimensions across L61, LE5, LSJ, LNF
https://imgur.com/O64Be6u.jpg
Bonus comparison differences between L61 LE5 LSJ LNF (crawl me googles)
https://imgur.com/QdKWhqU.jpg
On a LE5 you DO NOT want to upgrade to LNF valves. As you can see in my pic an LNF has less of a dish therefore it'll raise the compression. I added LNF valves to my LE5 because I am planning on keeping it NA. If you want to upgrade the valve and go turbo there are better options.
If you plan on running E full time and or going full build you're good but on pump stock bottom end I'd spend my money elsewhere
