Supercharge a 2.4l
I've got a 2.4l sport 2008 and I'm looking to put a supercharger on it running stock boost for safest results looking for alittle bit more power not a ton but was wondering if I could leave the internals stock without hurting anything or having to rebuild the entire engine with new pistons and such
HP goals wise?
Don't know the "stock boost" on a 2.4. it differs from the 2.0SC |
Originally Posted by DFZ24
(Post 7611039)
HP goals wise?
Perfectly fine at that level. Much more will be pushing it.
On a blower 2.4, i'd use a standard 2.8" pulley and 42lb injectors, should be plenty for that setup on stock internals, and no reason to rev it super high. |
Originally Posted by ItalianJoe1
(Post 7611060)
I'd beat it, what's the point of adding power if you don't use it?
I meant RPMS in regards to the injector sizing. I would rev an LSJ to 72-7400 at least. On an LE5 I'd keep it under 6500, so you can get away with a little more air on a little less injector. |
Ive been wondering the same thing I have a 2.4l 2006 and want to super charge it but I have 180,000kmhs so im not sure if it will handle it.
Originally Posted by quiinybags
(Post 7611876)
Le5s love to rev btw. 7k or bust |
(Post 7611890)
Youll be fine. Those engines will handle anything an m62 can throw at it.
08 le5 will hold quite a bit less compared to the 06-07 models. 250 to the tire is the highest safest for 08-10 le5s
boost gauge: vacuum line plugged into the port on the intake manifold. switched power and ground at gauge, sunroof fuse...there's several dozen writeups and installs |
I wired my boost gauge to the ignition and then a ground. Also there should no le5 after 08
(Post 7647421)
run the factory LSJ 2.5 bar map; run the IAT wires from you MAF and hook them up to the MAP sensor.
you can net a lot better tuning results with air temps reading post blower. |
Originally Posted by Verbatim
(Post 7647426)
you can net a lot better tuning results with air temps reading post blower. I will keep that in mind though! Will the 4bar do for now where the LSJ one is now?? Btw, read your thread about your build. Epic man! And congrats on your new life journey! :guns: |
I could not answer that properly; I have no knowledge on the 4bar zzp has that you are talking about. is it part of the SC swap kit they offer?
there has to be a decent shop or individual local that is knowledgeable in HPT; head to the regional boards on here and do some digging. or get on the HPT forums and find someone local thankyou, I find new little things I hate more and more about my car every day as it starts showing its age. but goddamn, I love that little turd in my garage. And yes, I and very proud of where I am at in life and although I love my little one very much, it makes me happy that even at 4 months old, he is already showing signs of a gearhead in the making. God help us all, lol |
I used my stock map sensor for a while and then switched to the stock lsj map.
(Post 7647429)
there has to be a decent shop or individual local that is knowledgeable in HPT; head to the regional boards on here and do some digging. or get on the HPT forums and find someone local thankyou, I find new little things I hate more and more about my car every day as it starts showing its age. but goddamn, I love that little turd in my garage. And yes, I and very proud of where I am at in life and although I love my little one very much, it makes me happy that even at 4 months old, he is already showing signs of a gearhead in the making. God help us all, lol chevygirl, you tuned to run that though right?? |
