Supercharger Swap on LE5 in Volkswagen Baja Buggy
Not quite a Cobalt, but shares a few parts and lots of fun to drive!
A have a 1965 VW Baja Bug that I did a 2.4L LE5 swap on a few years ago (its out of an 06 Pontiac G6) It's mated to a VW Bus transaxle with an adapter kit. A few of you are probably reading this and thinking I'm crazy But the Ecotec swap is extremely popular in the "Buggy" community.
What's not popular is Supercharging them (in the offroad community)
I decided I wanted to pick up a couple horsepower so I decided to go for an M62 Blower Swap.
Last week I Ebay'd a "top swap kit" that included LSJ Manifold, blower, throttle body, fuel rail, injectors, alternator, pulley tensioner, Intercooler pump with mount and hoses.
I think that's about it. Everything is from a wrecked SS Cobalt.
I know I need to order some stuff up, and have been browsing the ZZ Performance site, and had the pleasure of speaking with one of their guys today.
Was planning to order the following, Please correct me if it does not sound like I'm on the right track. I'm very much a newb to this swap but am trying to gather information as quick as i can.
ZZP adjustable idler pulley
NGK 1 level colder plugs gapped around ~.035"
GM 2 Bar Map Sensor
Throttle Body Adapter Harness
Siemens 60lb injectors with EV6 conn
Blower oil and needle bearing grease
Laminova O-rings
A handful of gaskets.
LSJ Belt
I couple things I could use some input on,
Do I need to get a different crank pulley so I can run a 6 rib belt system, or should I leave it 5 rib and cut a rib of the belt?
Does anyone know what fuel psi is ideal to run with the 60lb injectors?
The LSJ alt that came with the kit looks pretty crusty and gross, can I run the alt on my LE5 and let it spin backwards?
Should I tap my endplate and convert to "dual pass" or is the factory config ok for smaller pulleys
Also, not sure if i want to try this first with the stock 3.35" pulley or just switch to modular pulley system with 3.1 or 3.0 pulley right off the get-go.
Also, when this is complete, it will be going straight to the dyno for tuning
GM 2 Bar Map Sensor
Laminova O-rings
LSJ Belt
Cutting a rib off the belt is fine, thats how mine is
Fuel pressure doesnt matter really, just keep in mind that the flow changes with pressure (they are 60lb/hr at 3bar)
I also have my stock alternator running backwards, works fine
Dual pass isnt necessary for stock pulley but id recommend it anyway because youre probably going to be wot a lot of the time
GM 2 Bar Map Sensor
Laminova O-rings
LSJ Belt
GM 2 Bar Map Sensor
Laminova O-rings
LSJ Belt
I had tap'd my endplate converting it to dual pass back in the good ole days and never had an issue with it. Would recommend for the cost of doing it yourself and the added heat transfer.
If spun in reverse, that style of fan does very poorly at functioning at all and what air it does move is pulled through the front, superheated by the rotor and stator heat and then moved past the diodes. Some have stated their alternator worked fine but just didn't put out as much. I am not sure what they were measuring, current or voltage but just the heating of any conductor which the alternator has a lot of increases resistance which lowers current output.
When I was with GM heads rolled in the late 90's over high alternator failures and they are over engineered today which is why they are surviving being rotated backwards but don't be surprised if you have premature failures or lower output.
Exactly... it's up to the owner and I am doing the same. Mine has 120K on it so I will run it till it dies. The alternator is not cheap and should it fail for what ever reason I would go with the correct alternator the second time just to get the air speed up. What is helping the type of alternator on the cobalt is it is a dual fan design. The dual fan designs pull air in like this when spun correctly so as you can see, it doesn't move all the air through the front superheating it and then take it past the diodes.
The down side of the cobalt or CS D Alternators being spun backwards is the efficiency of the fan drops significantly and the air cooling the rectifier assembly goes past some of the stator windings first. The nut loosening shouldn't be an issue but was in the past.
Dropped my harness and computer off today to have some stuff switched around.
I was previously running a Mefi 5 computer, I am now going to the OE style E67 computer. The harness needs a few things re-worked to accommodate the E67
A question came up about the MAP sensor and injectors I will be running.
I was under the impression most guys were running the 2.5 Bar LSJ TMAP in the manifold (The Bosch 0 261 230 042) while others recommend A GM 2 bar map ( GM 12615136 ) .......
Needless to say, I'm a little confused on the Map sensors, if someone could clarify, that would be great.
Also The harness guy thought I should run a Ford green top 42lb truck injector.
Can anyone confirm this or make an injector recommendation.
I will be running pump gas with a 3.1" or 3" pulley.
Thanks.
Thanks.
Turbodon1776 (06-17-2017)
My alternator has been spinning backwards for about 3 years and has not failed me yet (knock on wood) also i had a very hard time finding data for 60lb injectors. Even now im not sure i found correct data.
also you do have to grind down the head for lsj tebsioner to work. I had to grind down my alternator too as it was a different design for some reason.
If you have the time to allow, this is the proper way to characterize your injectors. $15/injector + shipping. That is dirt cheap and they will supply you the data in a format that is copy / paste friendly for HPTuners. Realistically, to build the map you would only need to send 1 injector.
Fuel Injector Flow Testing
