Aftermarket front mount oil cooler
Ever since I got my ZFR my coolant temps at the road track are out of control. I want to install a larger aftermarket air-to-oil cooler instead of the built-in heat exchanger/oil cooler.
I'm looking for recommendations or shared experiences. I found some information on here but nothing very specific. My coolant temps quickly reach 230+ after a few hard laps and continue to rise unless I abort my session. Here's what I've done so far in my track setup/tune: reduce boost from 26 to 20psi (remember I'm a 5,400 feet); Both fans turn on high constantly at 190F and over; purged any air bubbles from coolant circuit; AC delete - mainly to improve air flow to radiator I'm running the Mishimoto radiator and the (large) ZZP FMIC. I like that an oil cooler has the added benefit of some additional oil in the system. (1-2 qts) I'm aware of the functions the stock oil cooler performs in terms of heating up the oil quicker. This is not my DD so longer heat-up times are not an issue. Next track day I will run 90% distilled water/10% coolant just to see what effect that has. Might turn the boost down a little more although I really don't want to ;-) Any other suggestions for keeping temps down? Any big turbo guys that road track their cars that can share experiences? Thanks guys, Adrian |
Bump.
Nobody?? |
*Crickets*
I have ideas on how to do it but just a good derale cooler with ran will run you 250 bucks plus lines and all that jazz... A buddy of mine came up with the idea but it hasent been tested on a race track scenario yet but it will work I'm sure. It's on my life of things to do as well.
I'd ask ZZP what core they use on their bigger radiator, that's always an option even though then your Mishimoto radiator would be wasted money.
maybe a turbo blanket, improved air dam, larger/faster electric fans
Im doing one on mine. Welded -10 fittings to the stock oil cooler and routed to a ford oil cooler
Originally Posted by Omiotek
(Post 7401055)
(Post 7401150)
Originally Posted by Gunney_07
(Post 7401153)
I hadn't considered beefier fans. That actually does sound like a good option. Question is what's available that will fit without modification?
Originally Posted by JapEatr
(Post 7401165)
You want to get the biggest possible lines and cooler you can fit.
My idea and a few guys have done the original lsj piece but is to weld -10 or -12 lines and run a a short height long length and wide with cooler with 2 mini fans and a thermostat. You need to find a high pressure point in front of the car to force hair through. Some ducting would be beneficial too. |
(Post 7401238)
I was also looking at a Derale, with a built in fan.
I had the ZZP radiator on my list of potential cooling mods, until <someone with authority on racing these cars> advised against it (don't wanna mention any names). Chinese core, mediocre fabrication, probably not worth the money, or any more effective than the Mishimoto... I'm still not sure how a turbo blanket helps except getting engine bay temps down. By isolating the turbo, and preventing it to "radiate" some of its heat out, won't it just get hotter, heating up the oil and coolant going through it even more?? I hadn't considered beefier fans. That actually does sound like a good option. Question is what's available that will fit without modification? I'd be interested to know more about this. Do you have components picked out yet? Is there an easier way besides welding? Is it possible to remove the stock oil cooler and attach lines going to the new one? I'll try to post some up here shortly |
(Post 7401273)
My idea and a few guys have done the original lsj piece but is to weld -10 or -12 lines and run a a short height long length and wide with cooler with 2 mini fans and a thermostat. You need to find a high pressure point in front of the car to force hair through. Some ducting would be beneficial too. I was looking at this 15660 but it comes with only -8an lines... Would two of these in series be too crazy? lol http://derale.com/images/stories/vir...duct/15660.jpg
(Post 7401285)
Yes I have all the components... I have pics on FB and ARM Performance page'
You don't need to. Track cars don't even run 2. You can easily by an adapter from the cooler threads to -10.
(Post 7401380)
Adrian if you need help with the install let me know |
There is no such thing as cooler threads
I wasn't really serious on running 2 of them lol
Thanks for all the input guys! Eric I will probably need help with the install, unless I bring it in to Trent. It'll be a while though. This semester's tuition for Renee is due next week :( If it wasn't for that I could buy Cmiller's engine and have a couple grand left for cooling mods lol |
(Post 7401389)
Best place for the cooler is in the upper grill or between the subframe and oil pan mounted parallel to the ground |
I run an external setup on my lsj I can post a pick later it works very well
you will need to make an adapter plate to weld 2 -10 (-12 to big)male an fittings to I have an idea on that since the lnf dose not run an adapted oil cooler I just need one to tear up. and as for the cooler you don't need a super huge cooler with a fan and such a simple 10x11 or so will work. my car does not like to warm up on cool nights if you decide to try a bigger radiator I would give griffen a call and have them build a larger one the mishimoto radiators are not that good from what ive been told I built a setup for my friend he runs scca with an lsj his temps were 230 to 250(sometimes a little higher) at the end of the race he was running a big radiator waterless coolant and getting the oil of the cooling system allowed him to run a stock radiator and see temps at 190 by the end of the race |
(Post 7401417)
Mr b your also on e85. Cool night starts suck anyways lol. You only run a fan with a thermostat or no fan at all. You really would only need a fan in extreme track temp conditions. Mishimoto is not good. The fact they kept the core size the same is a joke. Call bell, griffen, Howe, or Ron Davis for a good radiator. I know ron Davis has built one before. I intend to build my own dual or triple pass.
(Post 7401450)
Originally Posted by mrbelvedere
(Post 7401494)
you will need to make an adapter plate to weld 2 -10 (-12 to big)male an fittings to I have an idea on that since the lnf dose not run an adapted oil cooler I just need one to tear up. and as for the cooler you don't need a super huge cooler with a fan and such a simple 10x11 or so will work. my car does not like to warm up on cool nights if you decide to try a bigger radiator I would give griffen a call and have them build a larger one the mishimoto radiators are not that good from what ive been told I built a setup for my friend he runs scca with an lsj his temps were 230 to 250(sometimes a little higher) at the end of the race he was running a big radiator waterless coolant and getting the oil of the cooling system allowed him to run a stock radiator and see temps at 190 by the end of the race That's impressive to go from 250 to 190. Are you saying only an oil cooler or only a larger radiator would be enough? I'd rather go big than get a solution that turns out to be inadequate...
Originally Posted by ECaulk
(Post 7401511)
It can be a winter project :lol:
(Post 7401514)
2 Attachment(s)
(Post 7401514)
1 Attachment(s)
the lnf from what I can find does not run a thermostat in the oil cooling system here is the plate to run an external cooler on an lnf
Attachment 19229 |
Hey i have one of those haha
(Post 7418129)
http://i779.photobucket.com/albums/y...psvopzx6x5.jpg |
