Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   ADVANCED Performance Modifications (https://www.cobaltss.net/forums/advanced-performance-modifications-130/)
-   -   the because I'm bored build (https://www.cobaltss.net/forums/advanced-performance-modifications-130/because-im-bored-build-313832/)
06blackg85ss Oct 30, 2014 08:37 PM
5 Attachment(s)
so after leaving my car sorta stockish for the last few years and messing with my other toys.
The cobalt is getting ready to be fastish again.
This setup won't be as crazy as I want, but will hold me over until my trans am is finished
current plans and mods are as follows:
Advise's tvs and id1000's
been on corn for a few years might as well stay with what works
Built sleeved bottom end (getting on saturday)
zzp stage 2 cams and 75lb valve springs
lots of nitrous
and our super secret cooling setup that is still being finished
throw in an exedy hyper single and a meth kit and that's the jist of it
shooting for @550-600whp on spray
will update as progress is made, bored so making this thread.
this is how the car sits as of now
Attachment 18979
Attachment 18980
and my fast car (finally just about done)
Attachment 18981
Attachment 18982
Attachment 18983
SunburstSS Oct 30, 2014 08:43 PM
Nice!
Whats up with the LS/LT bumper lol
Haven07 Oct 30, 2014 08:45 PM
Advise sold his tvs?
And this is what you do when your bored????:lol:
Looks epic!
Sl0wbaltSS Oct 30, 2014 09:00 PM
Don't spray, you're gonna blow really fast.
Mr Mall Cop Oct 30, 2014 09:10 PM
Sounds good
JapEatr Oct 30, 2014 09:14 PM
False
Looks good, im not sure 500 plus numbers are going to be feasible.
06blackg85ss Oct 30, 2014 09:19 PM
The two bottles of nitrous going in the trunk say otherwise.
It'll do it. Should be able to eek out 400whp on boost only. It can be done.
06blackg85ss Oct 30, 2014 09:22 PM
Looks epic!
Nah I'm just borrowing it until his car is done then either go back to the m62 and spray or something else.
And yes the lack of fast in my life is boring me so this is what happens.
Car has 190k on it motor that's in it now is John powells old motor and has been going strong getting the piss beat out it for years. But she leaks oil like a siv so me being me instead of fixing the leaks it's getting a new motor lol
06blackg85ss Oct 30, 2014 09:23 PM
Originally Posted by SunburstSS (Post 7428075)
Nice!
Airflow and fitting the front heat exchanger. It's far from finished though. Gotta do some body work and fit the ss lip on it then paint.
stealthy1ss Oct 30, 2014 09:24 PM
Is this the same motor that came with the car still? If so that thing has held up to anything and everything including revs in the 9k range.
Haven07 Oct 30, 2014 09:28 PM
That cooling system is intriguing....
And that trans am is going to be death on wheels:lol:
06blackg85ss Oct 30, 2014 09:32 PM
Nah that motor is floating around in another cobalt somewhere but still going strong. My 9500 rpm motor cracked a sleeve and the block and crank are sitting g in my garage. This motor I got from John years ago but it has seen it's fair share of abuse
06blackg85ss Oct 30, 2014 09:34 PM
Can't really go into detail on the cooling setup. But most it isn't even installed yet and already results have bee. Damn good.
And can't wait to get the ta out in the spring. Should be sitting around 800 whp with this setup. Eventually going for 1500whp when I build the next motor
SalvageBaltSS Oct 30, 2014 09:53 PM
OMG, That big ass turbo on that TA! What are the specs on that beast!
ECaulk Oct 30, 2014 10:28 PM
That cooling set up is interesting, how much coolant did you add to the system?
Your posts are worthless.
riceburner Oct 30, 2014 10:32 PM
Oh wow sounds like a blast!
06blackg85ss Oct 31, 2014 06:43 AM
trans am as of right now until I finish the motor for it specs are as follows:
pt88 t4 1.10 a/r twin scroll setup
rebuilt 5.3 w/ls2 rods and arp hardware.
317 heads with ls6 cam
slp ls6 oil pump
edlebrock proflo xt intake mani w/92mm throttle body
e85
holley dominator pro efi stand alone
8.50 cage
fti level IV th400 w/billet 4800 rpm converter
and some other stuff, also have a small nitrous kit i'm waiting to use to see how the turbo spools off the brake
06blackg85ss Oct 31, 2014 06:44 AM
system takes just under 1.5 gallons now. bad ass water pump on it too. twin temp gauges to monitor inlet and outlet from the laminova cores. Cruising now temp difference is only 1-2 degrees. inlet temps are ambient always (will be lower with the other goodies going in)
ECaulk Oct 31, 2014 07:20 AM
Care to share the flow rate of the pump? There was another thread discussing the addition of a high flow pump and some claimed higher fluid flow rates would increase the heat not decrease the heat like theory says it should.
06blackg85ss Oct 31, 2014 07:30 AM
it's emp wp29 pump, thing is a monster
and tested back to back vs the stock pump, temps are definitely down. pretty much monitor and log everything temp wise, adding 2 more air temp sensore pre blower and post blower before the cores to get a better idea of what we'll be adding to the car does.
as of right now will be running a single 15gph meth nozzle pre blower and a 30 dry shot of nitrou
then another 125-150 shot direct port nitrous kit post blower. with twin 5gph nozzles in the s/c spacer
ECaulk Oct 31, 2014 07:36 AM
Damn. Youre going to have one sick LSJ again
06blackg85ss Oct 31, 2014 07:43 AM
yeah didn't want to but, well my wrx is too slow and that engine is a time bomb, so might as well do up the cobalt again. Wait til the trunk shots are posted lol.
riceburner Oct 31, 2014 09:21 AM
i'm very interested in that cooling setup
06blackg85ss Oct 31, 2014 02:34 PM
it's a little over the top, but that's how it goes. Can't really post much until it's complete, still have about 4 more things to install to finish it up
but should make running small pulley no problem heat wise
jonathan923 Oct 31, 2014 02:49 PM
wish i could had seen the balt in person once done..my last day up here is wednesday :(
